Question about GPS
I have a new Garmin Oregon 400t GPS. It is downloaded with US Topo Maps. I bought the Canada Topo maps and I also bought and installed a 2 gig micro chip. I have loaded the Canada info on my computer and hooked the GPS up and can't seem to down load from the computer to the GPS. I have checked out the drivers on my computer and all is OK. What can I do to download the Canada maps to my Oregon? Thanks, Louis Solari (207-650-5365)
  • 10 Answers
SOURCE: Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Posted on Oct 04, 2007
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
SOURCE: new maps down load
for my GPS to update.
Posted on Sep 22, 2008
  • 121 Answers
SOURCE: wrong language on garmin oregon 400t
look up the words in the dictionary
Posted on May 03, 2009
SOURCE: I have a garmin oregon
Make sure you have your base map enabled. Go to Setup | Map | Map Information | Select your base map and enable it.
Posted on Jun 25, 2009
I have purchased zumo 595lm and have put topo mini sd card loaded with topo maps it has wiped out the origanal maps can i reinstall the origalmaps to it
Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to register it, as well as provide any current updates. Install any maps from this process on the device itself.
Jul 03, 2016 | Garmin zumo 595LM 5" GPS with Built-In...
Could not unlock maps
If you are having troubles accessing the pre loaded mapping then you may need a firmware update, if these are maps that you have installed make sure they are compatible authorized maps.
If you try this and all fails contact Garmin customer support.
Hope this helps!
Feb 15, 2011 | Garmin Oregon 400t Handheld GPS Receiver
Nuvi 1300
your GPS should be able to take you anywhere in the world so i don't see why it wouldn't work in canada.
Jul 07, 2010 | Garmin MapSource Topo Canada 2008...
Have a Garmin Oregon 400t. It does not want to recognise maps stored on the SD card. If I connect the Garmin to computer, I can read the files on the SD card but when I look to select the maps, they are...
Memory Maps are for PDA's only, not for Garmin GPS units. If you purchased these from Memory Map, contact the company and request a refund due to hardware incompatibility. Maps for the Oregon are from Garmin (purchase) or Ibycus (free).
http://www.ibycus.com/ibycustopo/
Jun 29, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Deleted or corrupted map files on garmin 400t
go to http://www.garmin.com , connect your device with the USB cable , install the connector , go to maps , click update , good luck
Jun 27, 2009 | Garmin Oregon 400t Handheld GPS Receiver
Usa maps
Good question.
First you have to go to Garmin and download their free program called WebUpdater.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current United States maps.
Jan 23, 2009 | Garmin MapSource United States TOPO...
Garmiin nuvi gps,
The device uses SD cards actually. They will not however work with TOPO maps or Bluechart. They are primarily for loading media or city street maps for other country's.
Jan 14, 2009 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
GPS position is offset from map location
This could be because your datum and your posistion format. Under your menu go to setup, then units and make sure you have the correct info set in there for your area. NAD27 Canada would be the one you are looking for. Give that a try and see if it works. If it is still off, consult the manuals that came with your topo and see if it says what datum it uses.
Nov 15, 2008 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
I have a garmin oregon 400t and I cant see the elevation lines, or topographical lines
You may be in an area where there is not enough topography for the topo lines to show up. Pan tothe Smokey Mountains and see if they show up.
Jul 22, 2008 | Garmin GPS
GPS Logo
44 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
