Question about Microsoft Office Professional 2007 Full Version for PC
Access 2000 and Access 2007
I have a datebase in access 2000 on disc, however my computer has access 2007. Whenever i open the programme in 2007 some of the forms wont function correctly. Are you able to assist
  • 2 more comments
  • lisajeff Oct 13, 2008
    yes it's a trial version. didnt want to buy full version in case problem persists
    can you provide instructions on how do this - do we need to open access 2007
    microsoft office 2007 smalll business edition
    thanks
  • garyY933 Apr 07, 2009
    I have a similar problem except I bought 2007 and installed it. Now none of the 2000 databases forms and modules work. I've uninstalled both, re installed 2000 access on its own but you have to install of 2007 thus the problem remains. Removed 2007 and still have the same problem with 2000!!!!!!!!
  • 64 Answers
Good day,
this is an issue about compatibility between access 2000 and access 2007. in other softwares, opening a file saved in an older version is not a problem, however it seems it's not true in your case.
try opening the file again and use "Save As" and use the access 2000 version, maybe access 2007 will "downgrade" its system and would make your forms function properly. however, if this will not work, you have to work on a computer with access 2000 installed.
i hope this helps
Posted on Oct 13, 2008
  • 535 Answers
U have to need a reinstall the software is full virson of software or trial virson of your software if the trial then some ficher are disbled if u have trial then upadate it in to a full version
  • sandip panchal
    sandip panchal Oct 13, 2008
    use this key to activate it if its work or u have to bue a new key
    office 2007 ent edition
    KGFVY-7733B-8WCK9-KTG64-BC7D8
  • sandip panchal
    which os r u using
Every thing i click on on my desktop starts then
I played around with W8 on an Asus notebook with a 1GHz CPU and found that each programme will open over the top of another.You could have many trying to run and causing the CPU to overload and freeze.
Waiting for the activity to slow from startup by observing the LED activity of the hard drive usually means all startup programmes have loaded and there is less draw on the CPU resources.Trying to access other software while startup is incomplete will compound sluggishness especially if the laptop is a netbook or has a low speed CPU.
If you experience the issue again please wait a few minutes before trying to access or cancel any programme to see if will work through any bottleneck created.
Sep 03, 2014 | Computers & Internet
Tip
Why some things dont work with vista or windows 7
The most common issue people have with these new OS systems,(windows 7/vista) is that they have a new form of security called 'administrator privileges'. Basically, your average user doesn't know about this, because most installation CD's or DVD's just auto-run when you insert them, and unfortunately, the computer most of the time does not prompt you to do anything special at all, and the software just installs. But underneath that installation, certain 'privileges' have been allocated to that installation, so here's the tip; Whenever installing new hardware or software, be sure to stop the auto-run feature, or close it down if it starts by itself, right click the disc or file where you are installing from, and select 'run as administrator'. If you are not the administrator, or do not have access to that privilege, then I suggest getting that access, or get the person who has it to give it to you! If you are installing from disc, go to Start>Computer and the disc should show there. Right click on it, select 'open' or 'explore', find the installation file (usually a .exe file) and go through the procedure above. Enjoy!
on Apr 16, 2010 | Computers & Internet
We put the disc in and nothing has happened to show/tell us how to get the wireless keyboard and mouse to work, what next.m
When you insert the software disc, most computers are set to autorun what's inserted into the disc drive. If yours is not enabled, you can insert your disc, go to My Computer, and right click on the drive with the CD, and click on Open, this should allow you to access the information on the cd. Just click on the setup.exe, and you should start installing in no time!
Aug 08, 2011 | Logitech Wireless Access Duo Optical...
Sometime back i had installed AVG on my laptop but soon enough it started blocking out a lot of the programmes that installed.SO i uninstalled it and deleted a few of the files too. But even now some...
Open your control panel and check if every program associated with AVG is been uninstalled on your computer? you can also open your firewall settings and for a minute try to disable it, just to know if the firewall is miss-configured which might block your programs from from starting. also make sure you are log on as Administrator
Let me know if this solutions works for you.
May 17, 2011 | AVG Antivirus + Antispyware 9.0 for PC...
Unable to open my desktop. The computer boots up
try to run your windows installation disc, and click on Second "Repair" button and try to repair it. should work.
Nov 24, 2009 | Computers & Internet
In my ViviCam 8018 digital camera's software and user manual disc, I cannot access the user's manual. How do I do so?
when you put in the disc, the installation window comes up. Close this down (click on the X), then go into my computer and right click onto the cd. A chart should come up showing you what you can do like play, auto play etc. left click on open and then you will access the cd. there should be a microsoft word document called users manual, open it (double click) and you have it!
Apr 26, 2009 | Vivitar ViviCam 8018 Digital Camera
Unable to open mail
You could try going to your Tool Bar and choosing Internet Options. Then change whatever address is in your homepage box to www.yahoo.com and restart your computers. It may allow yahoo to work. good luck!
Oct 18, 2008 | Yahoo Mail
I forgot my password
i have forgot my my smartphone i-mate k-jam openning password tell me how can i open my phone or remove pasword
May 29, 2008 | i-mate K-jam Smartphone
Cannot access files on h340
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Sep 07, 2006 | iRiver H340 MP3 Player
Microsoft Office Professional 2007 Full Version for PC Logo
1,225 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
