Question about Krups Small Appliances Espresso Machine
I have a krups fnb4 espresso machine need to remove filter and work out how to operate it
RTM !!!
Posted on Oct 24, 2008
Krups espresso machine pumps water out not through nozzle
Chances are that the input and or output tubes within base of machine are clogged, If running vinegar with water does not help. With some patients and small screwdrivers, remove base and tubes to clean. Be sure machine is unpluged. Also be sure heating element is working in base.
Dec 10, 2013 | Krups Coffee Makers & Espresso Machines
I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
May 10, 2010 | Krups Small Appliances Espresso Machine
Espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Nov 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups xp4030 wont push espresso thru and when you
I had the same problem. The metal filter is clogged with very finely ground coffee. To clear the filter, boil it in vinegar and let it sit for a few hours. Rinse the filter and run water through it in the machine (no coffee in the filter). I found I had to grind the coffee at the medium setting in order to keep the problem from recurring.
Aug 05, 2009 | Krups XP4030 Espresso Machine
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
I need a 2-cup filter
GOOGLE "2 cup filter for Krups espresso Novo 2100"and your problem will be solved.
Jan 29, 2009 | Krups Espresso Novo 2100
Lost operators manual for my Krups 888
The Krups website has all of the manuals available for downloading.
Apr 29, 2007 | Krups Caffe Centro 888 Coffee Maker,...
Krups Small Appliances Espresso Machine Logo
457 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
