Question about Air Tools & Compressors
Compressor will not reach the design pressure
The compressor runs great up to about 110 psi. After that pressure stops building and I have to shut it down manually.
  • Anonymous Mar 26, 2014
    compressor keeps running wont reach 135 psi
    Brigadier General:
  • 6,966 Answers
Let us try the easy possibilities first:
  • compressor piston/valves;
  • pressure regulator;
  • leak;
  • slipping belt/clutch;
  • air intake/filter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 13, 2008
    Novelist:
  • 159 Answers
If it is supposed to shut down automatically. Your pressure contol switch may have gone bad.
If it is rated to go higher then you may have bad compressor rings that won't allow it to go above 110.
    President:
  • 1,450 Answers
WHAT TYPE COMPRESSOR?BRAND AND MODEL
  • TripleTauto
    TripleTauto Oct 13, 2008
    if it is oilless compressor it is most likely piston sealsor a broken reed valve. if it is oil filled possibly a exhaust valve not seating
  • TripleTauto
    TripleTauto Oct 15, 2008
    have you fixed this?
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Compressors
The pressure regulator on an air compressor is designed to let the pump motor run until the pressure in the tanks reaches their safe level. While you are using the air the pressure drops in the tanks until it reaches the level where the pressure switch turns the motor on again and refills the tanks to their rated level. The pressure where these two things happen is usually with in ten psi above or below the rated levels because few regulators are so precise and are affected by temperature that they turn and off exactly at the rated pressures. If a pressure regulator is damaged or broken it is possible for the tank to either reach unsafe high levels or not turn on when the pressure drops to where it should restart the motor. If you are in doubt, have the regulator checked or replaced as overpressured tanks are very dangerous.
Jun 24, 2012 | Craftsman 150 PSI Air Compressor
I have a central pneumatic compressor 21gal 2hp a couple years old the unit runs but will only pump up to 75psi and keeps running and does not build more pressure.It was building up to 110psi and then it...
Its the pressure regulator, if you discharge the air and can set the regulator to a lower psi, and it pumps
to that psi. you will have to replace that part, make sure to have make, model , serial# of compressor
so that the correct part can be fittted to you compressor. good luck!
Jul 31, 2011 | Air Tools & Compressors
I Have a 5.5.hp oilfree air compressor that builds air up to 45 lbs an stops building pressure and keeps run.will not shut off
Is you air regulator working? I suspect your reed valves in the head need replacing as they may not be holding pressure over the 45psi that you mentioned, and are allowing the air pressure to defeat them which allows the psi over 45 psi to bleed back into the air compressor cylinder.
Oct 29, 2009 | Air Tools & Compressors
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
The compressor only reach 50 PSI.
Does the compressor continue to run but not build more pressure? In which case it is an air leak most likely, or does the compressor shut off at 50 PSI? In which case it is mose likely the pressure switch. If it is an air leak you can un-screw the guage and coat with putty or teflon tape and reinstall to clog the leak around the threads..
Jan 26, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Air Tools & Compressors Logo
375 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
