Question about Intel D845GVSR Motherboard
Beep sound when swith on
When i turn on the cpu, sometime can't work, there sound beep. and the display tell me, that the cpu error becouse overheat, what its mean
so sometime when i work, it shutdown it self
how to fix it, please send to my email, wiramayasa2001@yahoo.com
thank you very much
  • 64 Answers
Good day,
a beep from your cpu system means that there is an error. and since there is a "cpu overheat" error, it could mean that your cpu cooling system (or its fan) is not working.
the shutdown is a defense mechanism of your cpu in order for your cpu not to self distract.
have the cooling system replaced as soon as possible to avoid further damage.
i hope this will help
Posted on Oct 13, 2008
Error beeps
it's overheat or critical error problem
try to remove dust from coolers and memory modules
and if it don't work try to change PSU or RAM or CPU
Oct 28, 2012 | Asrock N68S Ucc Socket AM2+ GeForce 7025...
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
Hi My compuer won't boot up it has a msi km2m motherboard I heard 1 beep I changed the power supply and made sure the ddr was seated and tight now i get no beeps but does not display anything on the...
Do this, first disconnect your memory into motherboard slot and then power on your PC. if you hear repeated beeping means no memory installed, the motherboard work fine. try to insert again your memory. if your memory are two pcs. insert only one memory and then power on again your PC. (only one by one insert memory for testing so you can trace if one of your memory was defective).
Try this,
Motherboard beeping troubleshooting guide.
(Note: before touching computer parts like motherboard, memory, video card and specially hardisk the very important parts of PC. discharge your static electric into floor ground or the case of your power supply. need also external PC speaker. if no onboard PC speaker ).
No beeps means short circuit, no power, bad processor, open parts or defective parts specially capacitor parts.
See this sample picture of capacitor leakage and defective.
One beep means everything is normal the motherboard work fine.
Two beeps means cmos bios error and defective.
One long beep, one short beep means motherboard need tracing defective parts specially capacitor.
One long beep,two short beeps means videocard problem need tracing of parts CPU and blower fan for working good, also capacitor parts for leakages.
Three long beeps means keyboard error some key press stock up or modules parts defective.
Repeated long beeps means memory not detected, loose of defective
Continuous Hi-Lo beeps means CPU overheat or loose blower fan with heatsink into motherboard chassis.
Try this solution for your motherboard troubleshooting solutions.
Hope this information can help you.
Thanks for using fixya
Aug 12, 2011 | MSI KM2MCOMBOL-6738-010 Motherboard
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
When the console is turned on there is a red blinking light around the power button
How many red lights?
If it's a full circle, then that means it is the dreaded red ring of death. This means that your console's hardware has had a fatal error and will not work. If your still under warranty, contact Microsoft and they will fix it for you.
For future information, this red ring of death is a very common problem with the 360. This is why; Microsoft made a mistake in the design and basically surrounded the entire internal organs of the systems with an aluminum shell, making overheating a real issue. When your system overheats, the sauter (SP?) holding your CPU (The Central Processing Unit, the thing that basically tells your system what to do) has softens, and your CPU begins to rise. Sometimes this will cause a single red light, which means an overheat. When this happens enough, or if the system gets hot enough, then the CPU will actually lift itself from the connection almost completely, meaning that the CPU is no longer connected. There is no way to fix this without Voiding your warranty, so you have to contact microsoft for them to fix/replace the system.
Dec 27, 2008 | Microsoft Xbox 360 Console
Intel D845GVSR Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
