Question about Dishwashers
Error code FA diplomat model no adp8332, tried resetting. no joy HELP!!!
This fixed mine, the base was flooded. I took off the bottom front pannel and discovered it full of water and sludge, I mopped it out and cleaned it the best i could and made sure that none of the wires/connections were wet. (I unplugged it first ! ). Then put the cover back on and tried it.
Works like a dream now.
I know this is better late than never but i've been searching half the morning for an answer and only just found a suggestion that steered me in that direction. So i thought i'd answer this so that someone else might not waste the morning like i have.
Have Fun
Posted on Feb 12, 2009
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
What is Error Code FA on the GE fridge GN26GMDES French door model
It could be F8 AS CANNOT EVEN FIND A ERROR CODE FOR FA ? if one of the LED segments at the bottom are out. That's a failed EEPROM. Replace ERC.
Read more: http://appliancejunk.com/forums/index.php?topic=14041.0#ixzz3dj9Ns0UZ GE Profile range JS968S0K2SS error code FA
Jun 21, 2015 | GE Refrigerators
FA error code on screen Tomy Walkabout Platinum monitor
Hi, I've had the same problem with the Tomy WalkAbout Platinum - and, indeed, no help to be found on any website.
Eventually traced the problem to the temperature reset button on the child unit (the blue button to the side). This button was lodged solid in the device; on inspection because of the wire of the temperature sensor.
I've opened up the child unit (remove the four small screws with a watchmakers screwdriver) and removed the entire temp. reset button.
The set up works as normal (but with a bit of gap). With a bit more time, you might be able to fix the temperature sensor wire and get the temperature reset to work again.
Regards,
M
Feb 21, 2010 | Tomy Freestyle Baby Carrier
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
No power on diplomat ADP8332, No lights on but fuse is ok
Bad connection on the switch, refitted spade connectors and it fired up Ok
Oct 27, 2009 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Dishwashers Logo
489 people viewed this question
Top Dishwashers Experts
