Question about Sony DVP-NS50P DVD Player
How to change from tv to dvd mode
I have a new sony dvd player and a philips tv
I am unable to switch from tv to dvd
dvd plays the count but no picture or sound
what can I do about ths problen
    Sergeant:
    Champion:
  • 318 Answers
The difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Posted on Apr 01, 2009
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
I have a Philips DVP-3010 DVD player which I purchased in Europe and thus it was set to PAL video output mode. Connecting it to a US television (which understands only NTSC) and playing a DVD produces a...
Check that the TV doesn't have the option to display PAL transmissions. It might be able to do it via any of the connectors. Otherwise your best option is to find a TV that can indeed convert both signals, or get a converter box.
Apr 04, 2017 | Philips DVP3020 DVD Player
We have a philiips dvd recorder, but unable to
switch tv to the input mode you have conected dvd to e.g ( AV or EXT ) if dvd is a recorder one have you put areal in back and tuned in dvd recorder
Nov 28, 2009 | Philips Televison & Video
Sony dvp ns67p plays dvd's at a quiet
I changed the audio settings to TV MODE.
and now the volume is perfect
Oct 05, 2009 | Sony Televison & Video
Sony DVD player DVP-NS700H unable to play DVDs.
the dvd player lens damaged. -please change it with good technician
Sep 21, 2009 | Sony DVP-NS700H DVD Player
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
Apr 21, 2009 | Sylvania Electronics - Others
TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Feb 27, 2009 | Philips Magnavox MWD200G DVD Player
How to convert my Philips DVP5990 to play PAL?
Press SETUP
Use the arrows to highlight Video Setup Page
Select TV Type - change it to PAL
There isn't a way to view PAL and NTSC at the same time with this player, but you can always go to the video setup page and switch between the two. Restoring the player back to its factory defaults will automatically switch it back to NTSC.
-Tha Mp3 Doctor
Feb 13, 2009 | Philips Televison & Video
Sony DVP-NS50P DVD Player Logo
1,024 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
