Question about Hitachi 53UDX10B 53" Rear Projection Television
Colors drop- similar to convergence problem
I had the convergence fixed two years ago and thought that was the same problem here. The repair person says the DCU has failed and needs to take in to the shop. Est cost $500 - $700
I am wondering if I am just throwing money out the door at this point or if this is a typical age related problem.
Thanks
  • DJC61 Oct 13, 2008
    Thanks Marty. He did put the grease on last time but still did not last long. Any ideas where I can pick up the IC?
  • 38 Answers
No i think he is taking u for a ride. u just need convergence ic and what happins is sometimes tv service centers will use sup replacemeet parts in stead of original parts u need to replace the convergenc ic whit original parts.and if they donot put heat grease on the convergence ics and that is y they go out again. but i have never seen the digital convergance unit go bad. and this problem can be repaird in your home for 200. - 250.oo at the most marty
Posted on Oct 13, 2008
  • dkreavis Oct 13, 2008
    yes all u have to do is put the ic number witch may be a stk4274 and the web will find the part for u.if not give me the number and i will tell u where to get it marty
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I cannot set ip the convergence in the setup menu, 2 years ago a similar thing happened and the repair man said it was the convergence chip and a fuse. does this sound like the same problem? mikw
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Concave tv screen colors distorted just had tv repaired one year ago for same problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Kp-51w5510 convergence intermitten
  • Screen looks 3D
Nov 28, 2008 | Sony KP-51WS510 51" Rear Projection...
All screen is red
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
Nov 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Do we need a new TV?
I dont think this problem can be fixed without solder work or part replacement of convergence section. Its no just matter of fuse. You should get repair facility from concern service center because TV has dangrous voltages inside and qualified person knows how to deal with TV.
Jul 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergence without a remote
First off, you do need the original remote to adjust the convergence, Second, the service mode will not fix your problem. If the colors have all drifted, you have a problem in the convergence drive circuit. Most likely the convergence IC's are bad or going bad. The service menu is not a fix all for the problems with the convergence. The service mode will or can make minor convergence adjustments,not anything where all the colors are off. If you have no solid state repair experience, call out a service person to assist you in this repair. Good Luck
Oct 15, 2007 | Philips Magnavox 51MP392H Rear Projection...
Convergence floating
First thought should be that you have bad solder conections resolder all around the vertical and high voltage and see if that clears up your problem. good luck windman
Feb 13, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
