Question about Tecnik TKL9260 Front Load Washer
Hose connection in bottom of machine leaking right hand side
Hose has 3 connections 2 with clips & one which is connected to drum with glue or mastic.
Where can i order the part ?
Cheers
  • 64 Answers
Good day,
what is the extent of the hole or loose connection of the hose? if it is not so bad, you can use some high quality sealant that you can buy from your local hardware. however, if the damage is very bad and could not be fixed anymore as suggested above, you can contact your seller or the local hotline for tecnik or their service center for service and replacement of parts.
i hope this helps
Posted on Oct 13, 2008
Filter
These model appliances have the filter as part of the sump assembly, you will need to unplug the appliance, on the back of the appliance is an access panel held on by screws, remove this and the pump assembly is on the bottom right hand side and the sump will be connected to the bottom of the drum assembly by a hose clip, inside this black pipe is the filter
Apr 12, 2014 | Hotpoint WMA54 Front Load Washer
Problem : Water leaking out from under washing machine
NOTE. PLEASE UN-PLUG THE UNIT FROM THE ELECTRICITY SUPPLY BEFORE ATTEMPTING THE FOLLOWING JUST TO BE SAFE:-
Problem may be due to a blocked dispenser hole. Completely remove the dispenser unit and check for blockages in the hole where the water goes in. If you cant see anything immediate, take the top off. (Remove the 2 self tapping screws on the back holding the top on). Looking at the unit from the front. look inside where you took the top off and locate the rubber hose that connects the dispenser unit to the drum (it's a tight space, but if you look inside , front left you will see where the hose connects to the drum). Remove the hose and check for blockages. (The hose just pushes into the drum). Let me know. I had a similar problem and found that somebody had shoved a sock and pair of knickers down the water dispenser hole. This was also causing the machine to make a loud noise when spinning. Have you also checked the filter in the bottom right hand corner of the unit ? You have to remove the kick panel to get access to it.
Jan 20, 2010 | Ariston Technologies Washing Machines
Where is the filter on Hotpoint first edition washing machine ?
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint First Edition FEW12 Front Load...
Where is the filter onwma56
If your Hotpoint washer is a similar design to mine, you'll not have a user-accessible pump filter, so - presuming you're happy doing it and the machine is unplugged from the electricity of course - I rectified by the following:
1. Switched the machine to 'pump-out' and got rid of as much water as possible.
2. Unplugged and disconnected the pump-out pipe from the house drainage and drained off as much additional water as possible into a bowl by gravity.
3. Removed the panel at the bottom of the back of the washer to expose the pump, the bottom of the drum and the main washer motor.
4. On the right-hand side, you'll see the pump with the grey (in my case) drain pipe and a wide black rubber pipe connected directly to the bottom of the drum by an adjustable metal clip
5. The wide black pipe attached to the drum contains a ball-filter and is probably the source of your problems - undo the clip (watching for water of course; though none was spilt when I did it) - and lower it slightly to reveal the filter and - hopefully - the odd sock or so!
6. Clear the filter of the obstructions (the plastic ball can be lifted out by the way to aid doing this)
7. Make sure the ball is back in place and connect the wide black pipe back up to the bottom of the drum - ensure the clip is secure
8. Replace the machines back panel
9. Connect the drain pipe back up to the house drainage
10. Do a test wash !
Hope that helps - in practice it took about 10 minutes all together and is pretty easy.
Sep 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
How do I replace the drum gasket at the rear of Model 97273100.
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
Jun 16, 2009 | Washing Machines
I need to replace the seal round the door but cannot remove the old one
Take the top panel off by removing the two screws underneath the lid at the rear and look down inside towards the front door edge of the drum you will see a very large metal hose clips holds the door seal on. A screwdriver will loosen the clip then the clip will slip off and then the seal can be removed and replaced
May 29, 2009 | Indesit WA 125 Front Load Washer
Ultima wf840 flashing f-05 dont know where filter is
I give you here the filter & pump details:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a ball. Lift it out carefully and you will probably find an obstructions like a coins or clips. Do not take off the white hose clips.
After the filter comes the pump, disconnect. Slide pump to left and lift, it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean out any obstruction and reassemble. Refit all as you dismantled.
Mar 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Our washing machine is only about 3 years old and it has started leaking from the left hand side down the bottom on the washing machine. It doesnt appear to be any pipes, it's coming from the actual...
Usually in a samsung
the pipe from the drum to the pump
inside the machine
comes away from the drum
the pump end is secured with a clamp
the drum end is a push fit
there is glue on the push fit end
but the amount is miniscule
Silicon adhesive: Contact Cement: glaziers glue: all work
the model number given does not show in my samsung lists so I cant give you exact instructions for accessing the pump hose, nor can I be certain that this is the exact fault
Not a solution, but somewhere to start
Sep 27, 2008 | Washing Machines
Front loading washing machine is having leakage problem
You need to work out where the water is coming from, either the front, back left or right hand side to give you an idea what/where to look.
Front - Open the door and check the door seal (usually grey rubber round the door) look for splits, chaffing, damage.
Rear - check the connection to the pump, there will be a (Black) rubber hose from the drum housing about 12-18"long, check for splits, connection etc.
Check and remove the pump itself, Isolate the electricity, to remove - disconnect the outlet hose from below the sink or upstand, lower the outlet hose to the floor and syphon off the water into a bowl from the machine, there will be some even if the machine appears empty. disconnect the plug on the pump (2 wires), disconnect the hoses from the pump (2 off) and check inside the hoses, bra wires, socks etc. look inside the pump for foreign objects, the pump can be wasily split open via 3 screws normally, refit in reverse order.
Top - remove the top cover usually 2 screws at back or side and will slide slightly to remove, check hoses to drawer and the hose below drawer to top of the drum housing, check the inlet solenoids at the back (where the water hoses connect).
hope this helps
Apr 08, 2008 | Washing Machines
Leak
Did it start to leak immediately? Or, did it start to leak as it filled about 1/3 of the way? You could have a loose air dome hose. This is the air hose that connects to the pressure switch. One end is connected to the switch and the other end is connected somewhere on the side of the wash tub near the bottom. If it came loose, this will cause a sudden leak. Check along the side of the wash tub (usually the right hand side on Kenmore) and see if the air hose is hanging free. If it is, reconnect it and your problem should be solved. Sometimes the hose will stretch over time and will not fit tightly anymore. There should be enough slack that will allow you to cut about 1/2" off the end and reattach. This will give you a more snug fit. This is about as inexpensive a fix that you can get.
Sep 06, 2007 | Kenmore 20722
Tecnik TKL9260 Front Load Washer Logo
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
