Question about Home
Delta shower probelm
When I turn the water on half way the water will come out of the shower head but when I turn it on all the way it stops. its only at the half way mark.
  • vrs912 Jan 04, 2009
    I had the same problem, and then the showerhead just stopped working altogether! I have a hand-held, and the water is coming out of the hose, but not the showerhead. It's a 2-yr old Oxygenic showerhead, btw. I tried soaking in white vinegar, and it didn't help. I also adjusted, and readjusted, a flow piece of the showerhead. That would help at first, but again, once I tried to get decent pressure, it stopped working. HELP!!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi kiehnsk,
I'm Harvey the Master Plumber.
Your problem is: when you turn the water on half way the water will come out of the shower head but when you turn it on all the way it stops. its only at the half way mark.
This is a common problem. Sometimes they come from the factory just slapped together, not tested. All the parts are there so you're going to have to adjust it. That's why I allways check the operation of the valve before I'm done. This is easier said than done. If you installed it yourself then it"s time to have some "fun". Turn the water off. Remove the handle and escutchen. At this point it depends on the model. Sometimes you pull out a part limiter and rotate 1/4 turn. Other times you pull out the guts and rotate a 1/4 turn. Then reasemble and test. You may have to do it a few times to get it right.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 13, 2008
I just installed a new shower with no tub. I have water to my delta fixture but no water out the head. I used shark bite connectors and did not solder the fittings
Are your walls still open? I assume they are as you'd be unlikely to close them up without having had tested your water flow. Here is what I would do.
1.) use the orange plastic C shaped release tool to depress the white plastic ring on the shark bite fitting that you have on the delta side of the Delta-ShowerHead connection.
2.) Carefully and slowly turn water on and see if water is exiting the fixture where you expect it to.
IF yes, water is coming out of the delta fixture then you know the flow problem is somewhere between the delta fixture and your shower head.
IF no, water is not coming out the delta fixture then you need to re-access how you connected the supply lines to the delta fixture.
Oct 24, 2014 | Delta & Single Handle Shower Faucet
When i hooked up a delta faucet for a handicap tub i had to put it on the right side of the wall so that the older guy could reach the handle to turn the water on and he wanted the shower head closer
Not usually, but there should be an inverter or other unit to activate the shower. Often it is in the tub outlet and blocks the tub outlet to force water up the shower pipes. If there is no such or if it is just not working you may need to run the piping up to a sufficient height and then back down to the shower head to create enough pressure resistance if it is as you say, requiring a specific height of pipe to get a specific back pressure. But there also needs to be a mechanism to force the water up the shower pipe. Look up Delta on the web and get a phone number as there will be someone at Delta that can fully advise you about this.
Oct 04, 2014 | Delta Home
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
Jul 27, 2014 | Delta Faucet Home
Delta handle won't turn more than half way
Take the handle off and adjust the hot temperature stop. Its just a plastic piece that needs to be adjusted up more. It just fits in grooves like a gear. Its easy to do.
Apr 19, 2013 | Delta & Single Handle Shower Faucet
Flow rate on delta thermostatic valve
the two screws are service stops open them all the way
Jun 09, 2012 | Delta & Single Handle Shower Faucet
When i'm filling the tub with water, the water back feeds up to the shower head and sprays out. I changed the spout and also moved the shower knob to make sure it wasn't stuck in the up position for the...
You will have water coming out of the shower head when you have really good water pressure. There might be more water volume coming out through the valve then what the tub spout can handle and in turn sends the water up to your shower head. When you fill your tub try turning the water only half way on not at full pressure, does this keep the water from coming out of the shower head? Most likely your valve has a 3/4" supply line while your shower head and tub have only a 1/2" supply line. Sounds like you have more volume to the valve than what the tub spout can handle. You might consider one of two things: 1) you can put a water regulator on the main supply line going into the house to lower your pressure, or 2) change out the supply line to the tub spout, increasing it from 1/2" to 3/4". Let me know whats going on.
Dec 03, 2010 | Delta Home
Just installed a waterpic shower head, half the water comes out of faucet and half the shower head, any solutions?
If your tub spout has a knob that you lift to divert the water to the waterpic then replace it with a Delta service part #RP17453 pull down spout. It always sends 100% of the water to the shower head and will always snug tight to the wall.
May 24, 2010 | Water Pik & Wallmount Showerhead
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Home Logo
423 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
