Question about Xerox WorkCentre XD120f Copier
Xd 120f xerox
It was working fine went away from work for while and came back with the printer showing error code E7 and not photocopying.asked employees how it happened they dont know
    President:
  • 2,072 Answers
An E7 is related to the scanner. The lamp carriage is gettiing hung up on something or a cable has broken or popped off a pulley. What I have seen most of the times, is the lamp carriage is hitting the sensor that tells the machine the lamp is in the ready position. Biased to the left side of the machine. remove the platen glass and see if you can move the lamp fairly easily. And when movine it back to the left, pay attention if you feel it hitting something.
Also here is the procedure to clear the code.
Performing a Fault Reset 1 01 will reset your Scanner, and allow you to check the Scanner for broken parts as it moves.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [1's] Key to enter 1 in the LED Display, as if you were to make 1 copy.
  5. Press the green [Start] button. '00' will flash in the LED Display.
  6. Press the [1's] Key to enter 01 in the LED Display, as if you were to make 1 copy.
  7. Press the green [Start] button. '01' will be in the LED Display and '100%' will be selected.
  8. Lift the Document Cover.
  9. Press the green [Start] button. The Scanner Bar should move from left to right under the Platen Glass.
  10. Visually check the Scanner Bar as it is moving to make sure it runs all the way across.
  11. Check the Mirror that follows the Scanner Bar to see if it is broken or cracked. NOTE: If you need to see the Scanner Bar and Mirror move again, press the green [Start] button again.
  12. Press the pink [Clear] button four times.
  13. The WorkCentre should now warm up and come to ready.
Posted on Oct 14, 2008
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
My xerox worcentre 103f shows the errors e7 - 15 where can I get a list with the code
The error code e7-15 is a copy lamp problem. There is a list of error codes for the Workcentre 100 series at this link.
http://www.partsdrop.com/pages/XD100inf.html
Jun 10, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
E7-03 error code on work center xe88 xerox
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Xerox WorkCentre XE88 Laser Printer
Xerox xd120f showing error code E7 and not copying
I had E7 and the unit required a new laser unit. Precision Roller had the replacement laser, which did correct the error. Apparently, during a move to a new location, something jarred the machine and caused the failure.
Oct 06, 2008 | Xerox Office Equipment & Supplies
Error Code: E7-21
plaese hepply this problem
Aug 10, 2008 | Office Equipment & Supplies
FLASHING ERROR 6 L
L6:The Main PWB sensed a Polygon motor lock signal error. 5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module. What that normally means is the laser mirror motor has failed. That normal price for that item is normally over $300. Here is a parts dealer to contact to see if they have it in stock. https://www.partsdrop.com/store/
May 15, 2008 | Xerox WorkCentre XD120F Laser Printer
232 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
