Question about GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZDI15C Automatic Icemaker Problem
Posted by jaycough on Oct 13, 2008 Report abuse
pump runs dry after several hours of running. water level in tank is lower then intake. When turning on unit, system fills up perfect, great pressure. it makes ice, but as soon as water drops pumps sucks air. seems like whatever tells it add water after initial start up is not working. anyone with sugguestion how to troubleshoot?
PS: i posted this several times, ubt it never seems like it takes. sorry if several
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: GE Monogram Icemaker #ZDIS15CSS
Let's try the easy ones first:
  • check pressure incoming water supply (consistent between 30 & 120 psi;
  • check the supply filter if you have one installed;
  • try a reset, unplug from the mains for a couple of hours to dissipate residual power. Hopefully this will revert the unit back to factory defaults;
  • double check the water level sensor.
Other than the above, all other diagnosis and test would require opening the unit.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 13, 2008
emissionwiz
  • 74896 Answers
All these machines use a sensor to regulate the flow of water to make ice, this is the weak part in the system, have it changed and the problem will be cured, I have first hand knowledge of this problem so I know the fix is correct.
where is this sensor located?
Posted on Jan 05, 2010
GE Automatic Icemaker Model ZDIS15CSSF, won't make ice.
These units often have a hard-to-see reset button to resume proper operation. Look hard or check your manual.
Jun 22, 2015 | GE Monogram ZDI15C Automatic Icemaker
Sounds like washing machine when running
it may be not getting the right amount of water check the float or soliniod valve if it is equipped.
Jul 16, 2014 | GE Monogram ZDI15C Automatic Icemaker
Water keeps running and the ice maker isn't making ice
The ice maker will not make ice with the water running in contently this keeps the water temp to high. Turn machine off, cut water supply off to machine, remove water inlet valve, ether take valve apart and rebuild it or replace the water inlet valve. Reassemble in reverse order and machine should make ice.
Jun 29, 2014 | GE Monogram ZDI15C Automatic Icemaker
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram Ice Maker
Could you please describe the problem you are having a little better?
Nov 21, 2012 | GE Monogram ZDI15C Automatic Icemaker
Manually add water?
Put 2 cups of water into the maker.
Jun 20, 2010 | GE Monogram ZDI15C Automatic Icemaker
Ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Nov 04, 2007 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZDI15C Automatic Icemaker Logo
85 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Audie Bogus
Audie Bogus
Level 1 Expert
Jay Finke
Jay Finke
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
