Question about New Home Sewing Machines
Hand wheel won't move on My Lock 1340
I can't turn the hand wheel on my serger.
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Serger Machine
Looks like you have a problem with either the wheel or the gears. I would recommend getting a professional to take a look, as we cant do any thing more in this forum..We can only offer you guidance..
Posted on Jun 28, 2008
  • 55 Answers
SOURCE: My hand wheel on my
your machine needs servicing. make sure you oil all spots indicated in your user manual and turn handwhel by hand for a minute or so to work oil in.
if this doesn't make machine easy to turn see a tech for full service.
scott
Posted on Jul 26, 2009
Tally Girl
  • 1117 Answers
SOURCE: Problem with a husky lock 340 serger. Wheel on
My Bernette did exactly the same thing as you describe and when I took it to the mechanic there was a gear right inside that had split on the main drive path. It was a nylon gear and it had cracked right through the middle - my machine was about 12 years old at the time.
After one store advised I junk the machine, I then priced the part from Bernina head office, spoke to another mechanic and he was able to send my machine to another mechanic he knew who could pull the thing apart quicker because he'd done the repair before. I was warned it would cost $270-350 but I love the machine so said go ahead.
I'd suggest you take your husky to a local husky dealer for a quote on this, it does sound similar.
Posted on Mar 17, 2011
  • 1696 Answers
SOURCE: My serger won't start. Motor is running but
Hi, On most of these newer machines they have a clutch that you engage to fill the bobins.
Please make sure that the clutch is disengaged for normal use. If this is all OK see that belt
is attached on motor.
Posted on Jun 05, 2011
I bought a used white serger model 523, the hand wheel won't turn?
Since it is a White, am assuming it is a mechanical machine. If so, most likely it has languished without use or TLC and over time, the oil has turned to glue and then varnish. When this happens, it actually freezes the moving parts--a very common problem with older machines. Sergers actually require more frequent cleaning and oiling than sewing machines.
If you are mechanically minded, you can try carefully removing the case. (Remember how it came apart!) Then while gently rocking the handwheel and using fresh, good quality serger oil or Tri-Flow Synthetic Oil, apply only a couple drops every place that metal parts rub metal parts. Avoid oiling synthetic parts and belts. The machine may even have built-in oil ports, but applying directly to the joints and knuckles will also work although not quite as efficiently. Avoid soaking it with oil and be sure to wipe off any excess. Then direct heated air from a handheld hairdryer into the interior of the machine. This may take multiple repetitions to get it loosened.
Or you can take it to a repair shop.
Sep 22, 2016 | Sewing Machines
Riccar serger hand wheel stiff
Could very well be seizing due to lack of oil or buildup of lint, etc. Sergers generally require frequent oiling with fresh good quality oil (consult the manual). Continuing to force the motor to run when the machine is seized can burn up the motor.
Sep 10, 2016 | Riccar Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
Pfaff serger hobbylock 4870 converter stuck on on
Have you tried gently wigging the hand wheel while attempting the change?
Aug 30, 2012 | Sewing Machines
Brother 1034d handwheel stuck
the best thing to do is take the machine in to have it checked.
sergers are nice & very useful, I have a babylock serger with the jet-air
looper threading systerm, and I use it alot when making clothes.
I even used my serger to serge the ends of fabric that I haven't used yet
so the ends won't fray.
Jun 11, 2012 | Brother 1034D Mechanical Sewing Machine
Babylock serger wheel won't turn to unlock
if you bought the machine from someone then you might think about
having the machine checked or serviced to make sure everything
is alright on the inside, since it's a babylock
Jun 09, 2012 | Baby Lock Imagine
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
Babylock Imagine serger was working fine, now light is only thing working, tried another foot pedal and still won't start? Any thoughts?
Can you manually turn the flywheel (towards you) - does the needle and loopers move then through the normal sequence?
If the answer is no, then its most likely something in the drive gear path, possibly a nylon gear inside it that has failed. This can be replaced but probably means a major dismantle of the internals.
You may want to take it to a baby lock dealer and see if they confirm that this is the fault.
I had this gear replaced in my Bernette 334D and it cost $250, part was only $25 of that charge.
Oct 17, 2011 | Baby Lock Eclipse Serger
Imagine BabyLock Serger. The hand wheel only moves a tiny bit and the gears grind. I cannot remove the needles because the needles are in the down position and the hand wheel does not move enough to raise...
I suggest having a professional look at it, if you don't have one near by. You can try to fix it yourself, but if release the gears the machine willl most likely get out of time and not sew properly.
How to release gears on each gear are 2 set screw, usually a hex head. just turn it counter clockwise and it will release.
But remember the machine will have to be timed, which is a bit to difficult to explain over text chat.
Apr 02, 2011 | Baby Lock Imagine
Sewing Machines Logo
Top New Home Sewing Machines Experts
Bargain Box
Bargain Box
Custom Exchange
Custom Exchange
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
