Question about Canon PIXMA iP1800 InkJet Photo Printer
Please help me...
My printer appears ink has run out but they already full..the ink doesnt recognized by the printer..what can i do about it...please help me i really need an answer..please i really need it so badly....i hope you can answer my question....
  • 74 Answers
Are you using compatible or OEM cartridges? The printer depends on a chip on original cartridges to set ink levels, most all compatible cartridges don't have the chip and the levels will not reset. If using compatible cartridges is the orange light flashing?
Posted on Oct 13, 2008
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
My ink cartridges cannot be recognized i just finished refilling it from a ink refill shop..i have already tried restarting the printer many times...still won't recognize...what should i do?...what is ...
The printer not recognized refill cartridge or compatible,or very rarely recognizes them.Put new cartridge original canon if you want the printer work.If i have been useful please give me a vote :).Thanks
Apr 11, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
Epson sx200 ink cartridges cannot be recognized. ink cartridge removed is almost half full
This is wel known kardridge genuine check problem.
Please see floowing links.
Hope this helps.
Aug 19, 2010 | Office Equipment & Supplies
Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Jul 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Refilled the black cartridge and now it doesnt recongize it
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Lexmark X5650 All-in-One InkJet Printer
Printer error requests that a full ink tank is empty.
You can try cleaning the electrical contacts in the printer and on the cartridge with isopropyl alcohol followed by water to see if that fixes it. Then you can try removing all your cartridges, turning the printer off, unplugging it, waiting a few minutes, plugging it back in, turning it on, and waiting for the printer to recognize there are no cartridges installed before you reinstall the cartridges. Otherwise you may have damaged the chip on the cartridge with static electricity when installing it. If this is a new cartridge I would return it to the store you purchased it from and ask for a replacement.
Jan 26, 2009 | Canon iP3500 Photo Printer
Canon ip1200 black cartridge wont recognize after i refill
Dear lim,
Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
Please rate this as fixya ok.
Dec 02, 2008 | Canon PIXMA iP1600 Printer
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
156 people viewed this question
old marine
old marine
