Question about Bosch Classixx WFO 2466 Front Load Washer
Power my bosch classixx shut down during wash ..no power, no display.Checked plug and fuse..ok.What else?
Just done a simple wash no problems, put on another wash on and a key appears where the timer appears and bleeps like it has finished a wash. could anyone tell me what this key means so I can carry on washing
Posted on Mar 15, 2011
Display not lighting up at all
The display / control units are sensitive to voltage surges and it was most likely damaged when the fuse blew.
Apr 28, 2014 | Bosch Classixx WFO 2866 Front Load Washer
Bosch 2467/GB/06 no display no go
Check power on wall with some other gadget, check plug fuse....
Apr 27, 2013 | Bosch Classixx WFO 2466 Front Load Washer
Shut down during wash. Now no power to unit.
Most likely the house fuse has blown or the thermal fuse inside the dishwasher has tripped.
If house fuse is ok then will need the model number to find location of thermal fuse.
Jun 26, 2011 | Bosch Dishwashers
Door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
We have a Bosch Classixx washing machine which infrequently stains quite badly items in the wash. Have made sure it is cleaned frequently
pull back door seal lip as far as it will go and you will find grey scum underneath this will stain your laundry during wash need to manually wipe out and put on 90 degree wash with biological detergent anything less wont touch it.
Nov 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1200 red wash light flashes but doesn't start
Could still be the water inlet valve. What you need to do is pull the washer out where you can get to the valve and the plug. Unplug the inlet valve and start the washer and when you start it as normal check the volts of the plug and see if its 110 if it is you know that the valve is getting power to open but not,replace the valve. If you dont get any voltage then it could be the relay or control board
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My washing machine keeps blowing he fuse in the plug
That means that there is a short or a contact inside the machine.
The short can be on power cable, on control panel, on in the internal wiring harness.
Apr 13, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx WFO 2466 Front Load Washer Logo
180 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
