Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the first time. F1 shows up and beeps and when I cancel it the same thing keeps happening every 15 seconds or so. I thought maybe it needs some kind of programming. The manual is no longer available.
  • Daniel Mar 20, 2013
    FixYourBoard.com fixes control board issues just like this all the time. You can view a report of completed jobs for your part number at their website. http://news.fixyourboard.com/
  • Anonymous Mar 14, 2014
    often when oven is on a f1 error beeps and displays clicking cancel does not stop the misfuction shutting off breaker does
    Master:
  • 505 Answers
GE Gas or Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
GE Range/Stove/Oven Fault Codes
F0 and F1 - Failed Thermistor Control - Replace Electronic Range Control (ERC)
GE XL44 Self Clean Oven Fault Codes
F0, F1, F7 Stuck keypad may mean relay is turned on. - Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 30 minutes to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
A call to serviceman may be required.
Thanks
Posted on Oct 13, 2008
    Sergeant:
    Champion:
  • 331 Answers
I think u should contact the customer care for the solution to the proggramming part....
    Sergeant:
  • 208 Answers
Hi.....
Hope this helps.....
Post back your comments.....
    Genius:
  • 1,847 Answers
This seem issue with the broken thermistor or other sensor that needs replacing.
  • Legin Varghese
    Legin Varghese Oct 13, 2008
    Error F-1 code means the control board has a defective Thermistor Control. Replacement is the only option.
    Retail parts dealers and appliances parts stores can also help
    determine what the possible problem may be based upon that specific
    brand and model. Bring the make, model and serial numbers. Dealers and
    appliances parts stores are listed in the phone book.
    Additional Suggestions:
    Read the manufacturers online web site for product information, problem
    possibilities, causes, solving methods, part locations, disassembly,
    reassembly methods, repair procedures, pictorials, schematics, repair
    and or owners manuals which may be available online.
    Cautionary Note:
    Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
    Thanks for using Fixya. Let me know if you want further information.
    Brigadier General:
  • 6,966 Answers
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 13, 2008
    Incidentally, you could try a hard reset. That is unplug from the mains for a period of time to dissipate residual/stored electrical power inside. This normally would reset the unit and revert it back to factory defaults.
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
GE model # jkp27 error code F1 what should I do?
Hi ssantillo,
Usually F1 error code means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope this helps.
Apr 27, 2011 | GE JKP27 Electric Double Oven
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
I have a Kenmore Super Capacity with UltraBake System. Model number 92004102. I keep getting error message E2 F3 and my oven door locks and my oven turns off. What does this earor message mean?
We have parts for your Kenmore range. You have a series of 3 numbers before the model number that's on your range. Those numbers tell us who manufacured your oven. Once we have this information, we call tell you which part you need to stop the E2 F3 error codes.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST Monday through Saturday and we can get you cooking again!
We look forward to working with you and getting you up and running again soon.
Thanks, Ella
Dec 11, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Error F1
The F1 usually means a problem with the keypad, not a sensor. You might want to try my fix for a similar problem with an F7 error message.
You can find my fix on this web site at:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over 1500 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Also, what is your model number, how old is your oven and where are you located? I am making a statistical study of this problem.
Regards,
Powerman
Dec 26, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
882 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
