Acer CRT Monitor with tic tac sound
I got a acer monitor with tic-tac sound when power switch on with led lite for a second and goes off and tic-tac sound continued.
Thanks
    New Friend:
  • 62 Answers
1. horizontel transistor bad.
2. dry points on neck board.
3. cheak the power supply out put
4. LOT problem
Posted on Oct 14, 2008
My monitor comes on and then goes off
Time for a new monitor. I have the same problem. Tried the monitor on three different PCs and it turns on for 2 seconds then goes blank, power stays on (green LED on power switch).
Temporary solution that worked for 1 day was to turn the brightness to 0 if you can manage to keep it on long enough to use the menu.
Jan 01, 2013 | Acer AL1916W 19" LCD Monitor
Acer crt monitor green light is ok but there is no display. but some time when i start computer it displays xp logo then goes away. i tried monitor with anoter pc but it still the same problem.
sounds like some of the components inside the monitor are becoming defective...the fact that you said some times you get a screen for a while then it goes away indicates a component is changing value when power is applied and shutting down the monitor...probably a capacitor in the power supply...best bet is to get a new monitor, as service rates would exceed the cost of a new or used one
May 19, 2011 | Acer Value V551 (White) 15" CRT Monitor
Tick tick sound appear from acer 15" crt monitor power supply circuit
the sound you heard come from power regulator. its just fine, just indicate that part are over heat.
maybe you ill consider replace your monitor with LCD. more friendly for your eye and less power consumption
Mar 08, 2011 | Acer AC 711 17" CRT Monitor
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Acer al1713 monitor and the power led flashes form yellw to green
The short answer, replace all of the capacitors. They can be bad without swelling. And there may be one 47mf/16v off to itself, if it fails, monitor will not come on. Also, check the menu or mode setting to make sure your VGA/DVI agrees with the cable if the monitor has both.
Jan 01, 2010 | Acer AL1713 17" LCD Monitor
Tic tic sound with L.E.D blinking
it can be a broken monitor or a faulty video card. try replacing your video card. hope this helps
Jul 03, 2009 | LG Studioworks 700S 17" CRT Monitor
Tic tic tic sound
Check for other problems. You might need to buy another FET as well. But this time don't put the FET back in until you make sure nothing can blow it.
May 15, 2009 | LG L1915S 19" LCD Monitor
Monitor Problem
I fixed the problem by acquiring a recovery disk that booted me into the bios screen and the screen came on. I then changed the settings, I still don't know why it happened in the first place though!
Thanks anyway though
Aug 23, 2008 | Acer AC 711 17" CRT Monitor
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
Computers & Internet Logo
531 people viewed this question
David Payne
David Payne
