My washing machine will not disperse COLD water.
My Maytag washing machine will not disperse COLD water. The HOT water works fine. Can you help me?
  • 1albatross1 Dec 14, 2008
    My washing machine has recently begun stopping at the coldwater rinse cycle. I have since concluded that cold water will not even enter the machine (when I set on Cold/Cold as a wash option, there is no flow). I've determined that there is ample water getting to the intake valve and that the screen is clear. Is there an electrical component that might be fried that won't recognize the existence of cold water?
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
SOURCE: Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Posted on Nov 19, 2008
onthejob5130
  • 640 Answers
SOURCE: cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Posted on Jan 18, 2009
SOURCE: Maytag Epic Z washing machine F20 error
F-20 error code its water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Posted on Mar 16, 2009
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Cold water just stopped flowing in,hot works
There are two electronically controlled valves in the back of the machine; one for hot water and the other for cold. It sounds like your cold valve is stuck closed or not getting the electronic signal to open. I recommend going to the following web site or calling 1-800-344-1274 for help from Maytag. They will want to know your model number and serial number so try to have that information handy when you call.
http://www.maytag.com/support/contact_us.jsp
May 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
No cold water to my Maytag Top loading washer
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
May 14, 2009 | Maytag PAV2300 Top Load Washer
Cold water just drips, hot is fine, good pressure.
turn off water then remove hose. filter is in the fitting on the machine where the hose connects. pull out filter and clean or replace it
Apr 19, 2009 | Maytag Dependable Care LAW9406
Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Apr 02, 2009 | Maytag Washing Machines
Cold water inlet on maytag top load washer not working
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
