Question about Garmin Rino 120 2-Way Radio
Rino 120 not locating satelites. Batteries die in 1/2 hour
Rino 120 that will not locate satelites on sunny day, no obstructions. The unit also heats up when turned on (maybe a short internally?). Batteries die in 1/2 hour or less. Ideas? WAAS is off, the mic is not stuck on. Are there any authorized repair centers?
  • Anonymous Nov 11, 2008
    i have the same problem, i loose satalites all the time , and the batterys die really fast. not a good situation when your a couple miles back in the woods chasing deeer around.
  • Anonymous Nov 12, 2008
    same not fixed yet
Mine was shutting off between 1 and 10 minutes. Was in the situation of either buy a new one or scrapping it. So I gave it a try. Removed all the screws and pried it open carefully wirh a knife at the bottom. Get the front cover off carefully and disconnect the speaker. Then disconnect the display by removing the pressure on the ribbon connector by releasing the connector lock. Then the cover is off. I looked with a flashlight and I could see corrosion on the memory backup capacitor on the other side of the main board at the bottom end, near the battery connector. Remove the ******** connector and the pushbuttons ribbon .Had to melt the 2 battery connectors solder points to take the board off. Sanded the 0.2 farad capacitor with a 600 sandpaper and cleaned it up with an old toothbrush and some lighter fluid. Put it back together carefully (thats 2 solders and 4 cables!) and turn it on and do a sat search. When you get the real time and date youre ready to go. I can again use my old rino 120 with confidence !
Posted on Dec 31, 2011
  • 55 Answers
My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER button and while holding the buttons turn ON the unit.
Reset is complete.
Dec 21, 2011 | Garmin Rino 530HCx 2.1 in. Handheld GPS...
An older unit. No service available from Garmin as it is obsolete. The 120's have a lot of problems. Poor battery life. Poor reboot and constant dying after on. I would find another unit.
Aug 10, 2017 | Garmin Rino 120 GPS Receiver
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the...
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Feb 09, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Waypoint selection uses last location instead of current location
Backup all data and reset the unit. Hope this helps...
Jan 14, 2009 | Garmin Rino 120 2-Way Radio
Batteries die quickly - unit gets hot
You may have a bad or shorted battery pack. You might try replacing it to see if the problem goes away. It would be normal, while charging for a battery to get warm. But not hot. Rechargeable batteries have a life expectancy of 18-24 months.
Oct 11, 2008 | Garmin Rino 120 2-Way Radio
RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Oct 02, 2008 | Garmin Rino 120 2-Way Radio
To make un full reset
Hello Rahooty,
There is no way to set the date and time becayse the system clock in your Garmin Rhino 120 should be updating based on the information it receives from the GPS satellites. The radio should auto locate itself within about five minutes of being turned on providing it has a clear view of the sky. Once it sucessfully auto locates the radio's clock and position should reset. There does not appear to be any other reset built into the device.
Try taking the batteries out for at least 5 minutes. Then, reinstall the batteries, turn the unit on, and give the unit 5-10 minutes to auto locate. If it doesn't, you may need to contact Garmin support for additional sevice.
Best Regards,
"Go Ahead. Use Us."
Jun 05, 2008 | Garmin Rino 120 2-Way Radio
Overheat/battery drain
Hello dogwillhunt,
It is normal for a two-way radio to generate some heat, especially during extended periods of long talk time. Consumer two-way radios tend to be much more susceptible to this because they tend to be constructed out of materials that do not dissipate heat very efficiently, such as polycarbonate and plastic. Periods of heavy transmit times also use additional power, causing the radio’s batteries to run down more quickly and require replacement or recharge. Use of the display backlight feature can generate additional heat and run the unit out of battery power even more quickly.
If the radio is heating up excessively and burning through batteries (pardon the pun) in situations where you are not using the LCD backlight excessively or transmitting for long periods of time, this may be indicative of a problem with the unit that would require service, such as a short or defective component. If such is the case, I would recommend contacting the manufacturer.
Agent Ken
Go Ahead. Use Us
Apr 07, 2008 | Garmin Rino 120 2-Way Radio
Garmin 120 just dies
have you put fresh batteries in
are they the right way around
are the 2 metal spring clips tight up against the batteries
try bending them (al little) to make better contact
has the unit had any water in/on it
is the mic button pushed down and draining the batteries too quickly
Nov 21, 2007 | Garmin Rino 120 2-Way Radio
Batteries in my Rino 120 don't last very long
I believe its 3AA's and it SHOULD last 15 hrs of life. You should probably check the terminal heads and clean them real good you might be shorting somewhere in the connection.
Aug 02, 2007 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
398 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
