Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark won't print
My Lexmark won't print.It will do a print test and it comes out fine. If i try and print something off a yahoo page, the word yahoo and it's heading will print, but the contents that i'm trying to print will not. I just purchased another computer. I moved and when i hooked everything back up, it wouldn't print, except for the print test and the Yahoo information that i stated. Does the info that you program into the lexmark has anything to do with it.
Have you selected correct driver ? What is the OS ?
Go to printer driver section and then print a test page from the driver. Just to check whether every this working properly.
Posted on Oct 21, 2008
First try printing a document from word, or the notepad application. If this doesn't print, then you may have printer issues. If you are just having trouble with Yahoo (internet in general), alot of times webpages are set up with "frames" and only the frame prints. An ideal solution to this type of problem is to down load a web printing tool like the Lexmark Printing Tool bar. It is available on Lexmark.com for free, and reformats web pages to save paper, and print easily.
Usually if the printer prints some part a document and it looks okay, then it is usually some communication problem rather than a printer problem. If the above paragraph does not fix the issue, then I would reinstall the printer and check to make sure neither of your cartridges are out of ink. I don't think that any data you personally input during installation should affect how it prints. I would try what I suggested above and hopefully these solve the problem
Posted on Oct 15, 2008
  • 64 Answers
Good day,
have you tried highlighting the entire content of the Yahoo! page before you select print? this may be an issue between the internet browser that you are using and your printer.
Posted on Oct 13, 2008
Buy a Canon printer they are the best, they come with EastPrint software that fixes all your problems
Iasked for help with a printing problem, The reply to my email address on 5 Sept 2012 to richardborley@yahoo.co.uk got deleted before use. Could Lexmark resend
Please update your printer firmware http://bit.ly/t7sPJR.
Please scan and email us a test page Press the Setup button > Maintenance > Print Test Page. ) from your printer after the update so we can evaluate the result. Please email it to LxkListens@Lexmark.com.
Sep 06, 2012 | Lexmark S405 Interpret All-in-One Color...
Printer shows it is printing and it just pulls paper through and nothing has printed. I have changed ink and still won't work. I've cleaned print head. It will only print black and not colored on...
A firmware update for your model addresses a number of issues including print quality issues. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update.
Should the problem persists, please contact Lexmark Technical Support Center for additional assistance. Thanks.
Oct 17, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
My Lc61 will not print black--on the test page, the colors are fine. I've replaced the ink cartridge and it says it's full but won't print
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
May 26, 2011 | Brother Office Equipment & Supplies
X75 My color won't work. Black is fine. I installed a new one at Xmas and it worked fine. I hardly printed anything.. Yesterday the test page with peacock showed no blue and everything came out yellow. ...
run the print head cleaner tool using the lexmark software. since you hardly used the color the print head nozzle is dried up and needs to be clean.
run the print head cleaner atleast 5-10 or more times as needed.
Mar 12, 2011 | Lexmark X75 All-In-One InkJet Printer
I installed the Lexmark z715 printer driver on my Mac and it is connected fine, but when you attempt to print documents, it prints blank pages instead. The ink cartridges are brand new. Please help me...
Ok, you need to clean the print heads they are probally clogged, what operating system are you using on your computer? I can walk you thru on what to do, very simple, if you have windows xp, do this: Go to start then all programs then go to your printer, there should be an option to align paper, clean print heads, print test page, you need to pick clean print heads, then after that print a test page, then if you see something printed but not good qaulity, clean print heads again....if this doesn't work you can take a damp cloth and wet and wipe under the ink cartilige where the ink comes out but is dried and clogged up until you see a rainbow streak of red, blue and yellow, be carefully not to wet any other part of cartirige, you can use a moist q tip if you want.
Jun 28, 2010 | Lexmark Z715 InkJet Printer
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
Lexmark Z600 ONLY print test pages
Seemes very daft, and sounds like a twit, but not really.
When I recieved the new cartridge I placed it in the correct cartridge retainer in the printer matching up the dark green colour of the cartridge and the top clip, and it printed nothing even after a tryed re-seating it.
So I placed it in the other thinking maybe I somehow might have placed it in the wrong slot, so I placed it in the other (Colour), and set that up as I did the other, and it printed a blurred page but then stopped printing.
After that I then placed it back in the other cartridge retainer, set it up as the previous times when it did not work, and then it worked.
Seems strange and simple, but it did not work the first time at all, and after faffing with it finally did.
This might help someone, and then again might not.
Oct 07, 2008 | Lexmark Z515M InkJet Printer
Won't print anything. always wanting to print a test page
hi this is a ink catridge align ment problem. u do one thing. go to printer properties and printer priference and go to service tab than u check ink catridge align ment.. than ur printer working fine...
Aug 18, 2008 | Lexmark X2500 All-In-One Printer
Problems printing out the z640
I took mine back and got a refund and bought an epson instead which is fine !
Jan 06, 2008 | Lexmark Z640 InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
1,227 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
