Question about Teac AG-V8060 Receiver
Teac AG-V8520 When I connected all the speakers in the Teac AG-V8520 no sound is coming out even if i put the volume up. I tried to connect the front speakers to spakers A & B and the other speakers to corresponding input but to no avail. Please help me before i bring it to the technician. There is no Teac service center here in the Philippines
  • Anonymous Mar 12, 2009
    I have the same problem with a TEAC AG-V8525. I tried unplugging it for a whle, and it came back on for a short time then went off again with "protect". Have not been able to get it working again. Would appreciate any help!
Same problem exactly
Posted on May 31, 2010
Teac AG-V3050. Everything looks right but puts out no sound to speakers. Have trien many speakers. Is there a fuse, reset, etc? Thanks
I nce had the relay for the amplifier die on one of my receiver. Basically this will allow the amp to power on and supply voltage to the speakers. Same thing though, i could access all of the menus, adjust setting, and volume but no sound because the amp never clicked on.
Oct 19, 2012 | Teac AG-V3050 Receiver
Can I connect an active speaker to the Teac AG d7900 output
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
Teac AG-V8060 Receiver No sound. If I turn up the volume all the way I get a whisper of sound from the speakers.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jun 04, 2011 | Teac AG-V8060 Receiver
How do you reset the blinking protect banner on the ag-v8520?
Try disconnecting the power cord then disconnect the speakers. Plug the power cord back in then hold in the power button until the unit "clicks." Then disconnect the power cord and reconnect the speakers, then the power cord and turn it back on.
Jun 13, 2009 | Teac AG-V8060 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Teac AG V8050
try using an antenna.
Dec 09, 2007 | Teac AG-V8600
Teac g-v8520 protect problem
Check the thermal sensor, TH1. This causes the unit to go into protect, it is a common failure part on this model.
Oct 26, 2007 | Teac AG-D8900 Receiver
Teac AG-V8060 Receiver Logo
1,766 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
