Question about HP Pavilion M703c 17 in.CRT Conventional Monitor
Color change Monitor has red color to it - Tried degassing it but not better
    New Friend:
  • 62 Answers
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Posted on Oct 13, 2008
Image is too red. I decreased the percentage of red on the menu of monitor. but the picture itself changes from time to time, so sometimes is redder, sometimes not. I tried to change the frequency but the...
Changing the frequency will not have an effect on the color of the monitor image. If there is a "default" setting or "Reset" button, i would do that. this returns the monitor to the factory default settings which are "usually" pretty good. Adjusting the red driver works as well but the other color divers all work together so it is not a perfect solution, mostly they all need to be moved to get what you need. When you reduce the red you are effectively increasing the other two colors. Based on what image you are seeing it will change but should remainthe same on the same image viewed in the same way, by that i mean you need to view the image in the same software each time for a valid comparison. images can and will change color if they are viewed with different software. Good luck, Worm1855.
Jan 20, 2011 | Computers & Internet
My 19 inch ViewSonic monitor shows red /voilet
Please check the VGA cable at both ends to make sure there are no bent pins and fit into the socket properly at both ends. Also try this monitor with other PC also since it can be in the video card.
Apr 25, 2010 | ViewSonic VX912 19" LCD Monitor
MY MONITER CHANGES COLOR AND ITS PISSING ME OFF HOW CAN I DO IT. IT ALWAYS CHANGES COLOR MOST OF THE TIME IT CHANGES TO RED COLOR
One or two of your color guns are failing. On a CRT, there are three color guns, Red, Green, Blue. They work together to produce all colors in the spectrum. If the monitor goes all one color, it generally means at least one color gun is failing. The cost to repair far exceeds the value of the monitor or the price of a new LCD panel.
Mar 11, 2010 | HP Pavilion MX70 17" CRT Monitor
With my d90 reds come out as orange how do i stop
My guess is that it's not the camera but it's your monitor calibration. Reds (especially brightly lit reds) are the most difficult to render on a monitor. I would try changing the Vivid color option on the camera as well as saturation and even the color space options to see if you get any variation. Also, consider looking into a monitor calibration utility. If you have a color printer, you can print an image that looks orange on your monitor to see if it prints the same way.
Dec 24, 2009 | Nikon D90 Digital Camera with 18-200mm...
Brand new monitor screen doesn't have any red
Take it back and buy a recognised brand monitor looks like yours could be a melon .Even a second hand one by Acer would be better.
Jul 29, 2009 | Soyo Computers & Internet
Viewsonic VA2012WB monitor too much red color
I hope there's nothing wrong the the RGB circuitry. Here's what i recommend. degauss, recall the monitor. There's also a temperature setting for the monitor. Change it to COOL or NORMAL.
Mar 15, 2009 | ViewSonic VA2012WB Monitor
My monitor was not red colour
Change the vga cord of your monitor. red,geen and blue signal from cpu to color monitor pass tru vga cord. if one line is cut for example red line is cut 100% there is no red color in your monitor.
Jan 06, 2009 | Computers & Internet
LCD lost the red color
First, plug a external monitor and toggle the screen with ALT+F4 to see if the image is correct there. This will discard software or configuration problems.
If the image in the external monitor is OK you problably have a hardware problem in the LCD panel or its cabling.
You can get the replacement parts here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 13, 2008 | Toshiba Satellite A75-S231 Notebook
Cannot change color on monitor
check the R.G.B voltages at the crt base.if it is ok the crt may be defective.
Apr 04, 2008 | E-Machines eMachines Monitor E15T4
Red color problem
As you are not able to see red color on your monitor means you will be seeing green+blue=cyan color your problem is that red signal is not coming to red cathode of your crt. please check 1 connector loose(cpu to monitor) 2 crt base loose. 3 loose or print or dry near red cathode circuit 4 red video output. 5 red signal from processor to red video is missing 6 processor ic. good luck
Sep 27, 2007 | SAMTRON 55V 15" CRT Monitor
HP Pavilion M703c 17 in.CRT Conventional Monitor Logo
491 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
