Question about LG 42PX5D 42 in. Plasma HDTV
Picture has gone blank
THERE was a click and picture stopped but sound continued , now i get neither.When i trun on green light comes on for a few seconds but no picture then green light goes off and red comes on.
TV is 2 yrs old
Suggestion on what problem may be and approx cost to fix in AUD$
thanks
NM
  • stephmcb Oct 18, 2008
    I have had the tv for 3 hours and this happened to me... the suggestion did no help as the screen is not showing any picture but is functioning as normal in the back ground. For instance, If you select the DVD player it plays the film and you can hear it but not see it.
    Sergeant:
  • 306 Answers
Press menue to see if the menue pops up (yanno for sleep timer and stuff). If not, you need to have it repaired or need a new tv. You could try unplugging it from power for a bit, might help.
If you can see the menues then and your using HDMI, switch to a regular cable line and see if it comes in. Or just tune to channel 4 or somthing and you should get snow. Could just be the HDMI cable.
But if you cant get ANYTHING not even the Ch3 or Volume to show up on the screen, its the screen, a fuse or somthing else
Posted on Oct 14, 2008
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LCD Screen blank
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | Acer AL2416WBSD 24" Monitor
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Green light at start up but green light goes off
sounds like your lamp may have gone out. check your manual as to changing lamp.
Sep 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Sep 18, 2008 | Toshiba 42H81 42" Rear Projection...
No picture; No sound
how many times does it blink red? It should blink so many times then stop then blink again. how manty times does it cycle?
Jan 02, 2008 | Sony KDF-E42A10 42 in. LCD Television
Continueus green flashing light
i have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
Oct 11, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
LG 42PX5D 42 in. Plasma HDTV Logo
131 people viewed this question
Computer Repairing
Computer Repairing
