Question about Pentax Cameras
Mirror jammed up on Pentax
When taking a shot the mirror on my pentax MZ-M 35mm SLR stayed in the up position. The exposure/film counter display has gone blank. Could it be the batteries? Any ideas?
  • wilfcat Oct 24, 2008
    Spot on - changed the batteries and now back in action. Many thanks.
  • 849 Answers
Yeah it is definatly battery broblem, replace it
Posted on Oct 24, 2008
    Sergeant:
    Champion:
  • 331 Answers
It will ceratinly be some matter with the batteries othrewise the settings may be faulty.......
Posted on Oct 13, 2008
Viewfinder blurry Pentax K100
The image is directed by the lens to a mirror then to a prism then to the viewfinder. The mirror flips up when you take a picture so the image can reach the film behind it. If the lens is ok it is possible that the mirror is very dirty or not returning completely to the proper position after a picture is taken. If the mirror is dirty you should have it professionally cleaned because it is a very light weight metal mirror and VERY EASILY SCRATCHED. If you have another lens then mount it and see if it is also blurry and cannot be focused.
A few cameras like certain Olympus models have a mirror lock up option which you use after focusing the image while the camera is on a tripod. This gets rid of the slight vibration caused by the mirror swinging up out of the way while taking. a picture.
If all else fails you might consider taking it to a good camera shop if you can find one.
Digital cameras are getting better and better but there are still things film cameras can do that most digitals cannot. Long exposures in "Bulb" mode and multiple exposures are among these. Also each brand of film has it's own Artistic color expression such as Afgachrome vs. Kodachrome.
Jul 16, 2013 | Pentax K1000 35mm SLR Camera
The viewfinder screen is completely black. no image whatsoever. it seems like the camera is functioning everything works from what i gather
Since it's a film camera, there are a couple of things to check:
1. You have left the lens cap on.
2. If this is a single lens reflex camera, take the lens off and make sure that the mirror isn't stuck in the "up" position. If it is, GENTLY pull it down until it stays down. At this point, your shutter may be open. Try cocking the shutter again, fire off a test shot, and see if the mirror sticks in the up position. If it does, you probably need to replace the mirror bumper foam - age can make foam deteriorate into a gooey, tar-like substance that can make the mirror stick in the up position.
3. Does the camera have a T (for Time) setting on the shutter speed dial? If so, turn it off the Time setting and set it to a manual shutter speed such as 1/60 - or whatever your 'X' synch speed is.
4. Your batteries died in mid-exposure. Replace the batteries. You may have enough juice in them to show the viewfinder display, but not enough to finish the exposure and close the shutter.
Nov 16, 2017 | Pentax MZ-60 QD 35mm SLR Camera
MIRROR WILL NOT RETURN TO POSITION LENSE BLANK
The mirror motor on most KX, MZ, and other late model Pentax film cameras has a small plastic gear on the shaft that cracks, so that it will not drive the mirror up or down. Pentax originally replaced it with a larger gear made with better plastic, but they had problems with those also, so the eventually went with a brass gear
I don't believe the part is available any longer, or so I was told last time I tried to order one. Which is fine with me, as they are a real pain to work on and I do not recommend you try and fix it yourself.
Sorry
Jul 06, 2012 | Pentax MZ-7 Film Camera
Mirror is locked open
Unless you have experience repairing cameras, this is not a DIY fix. Take your camera to a reputable camera shop and have a trained professional look at it.
Feb 03, 2012 | Pentax ME Super 35mm SLR Camera
The mirror on my pentax pz1 (film) camera is stuck
Mirror lockup often occurs if the batteries are flat.
Try new batteries first and if the problem remains please report back for further options.
Feb 13, 2010 | Pentax PZ-70 QD 35mm SLR Camera
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Dec 08, 2009 | Pentax ME Super 35mm SLR Camera
I cannot load the film into my pentax mz 60 it keeps showing the error message. I have no trouble loading the film into my second camera (same)
rootseya,
pentax error codes are in the repair manual for camera repair technicians. the camera needs repaired.take or send your camera to a camera repair shop for an estimate.
Dec 15, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Shutter
kirstyanne00,
open the film door and check the shutter blades. did you accidentally push the blades in when loading the film? if so take the camera to a camera repair shop, the technician may be able to reset the blades while you wait.
or send it to pentax repair center for an estimate cost to repair.
Oct 25, 2008 | Pentax MZ-50 35mm SLR Camera
Cameras Logo
93 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
