Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
About Sony Trinitron KV-28LS36B
Sony Trinitron Model: KV-28LS36B
DOES NOT RESPOND WHEN THE POWER BUTTON IS PUSHED OR WHEN THE REMOTE IS USED
WHAT IS WRONG AND HOW MIGHT I FIX IT?
I cannot turn on the tv anymore, the light flashes 10 times
    Sergeant:
  • 306 Answers
There are two possible defects in your circuit.
However, if the led blinks for about 10 times your tuner is defective 90%.
You will need a scope to check or you will need to take it in for service.
Posted on Oct 15, 2008
The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Sep 28, 2009 | Sony Televison & Video
Tv doesn't turn on.
Does this have a replacable lamp? If so it will do exactly this. If it does it's probably fried.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV shut off Sony Trinitron KV-32S20
I believe this uit has a fuse on the AC input on the main PCB. Yu probably blew that fuse.
Jan 16, 2009 | Sony KV-32S26 32" TV
Sony trintron--red lights
The 2 blinks is a diagnostic code that should indicate the problem circuit. This is unique to each model though. Can you confirm that the model in question here is KV-32FS120?
Thanks,
Dan
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony television will not respond to remote.
battery in remote.
Many times I will 'reseat' the batteries in a remote & then it will work for a while again.
Jul 27, 2008 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv doesn't respond to commands
Check the battery if its still good. if not replace with new one. if its still good, open the remote and inspect for loose connection. resolder if necessary. check also for possible crack pcb. good luck!
Feb 22, 2007 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
328 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
