Question about Canon Office Equipment & Supplies
No print head is installed in the cartridge holder. Open the printer's cover, then open the Inner Cover and install the print head properly. - I don't know how to do this...
  • 3 Answers
What kind of printer. I just installed a new cartridge holder on my kodat easyshare 5100 and it was just easy to snap in to position; you remove the plastic orange caps first. After you do this, if you still have problems with printing, uninstall your software complete, disconnect the cable from printer to computer and then reinstall the software (be sure to hook up the printer when software installation requests you do so and not before). Restart your computer and it should be working fine.
Posted on Oct 13, 2008
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
How do you remove the ink cartridges from the
To service the ink tanks:
Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
i_note_us.gif Note
If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2 Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3 Remove the ink tank whose lamp is flashing fast.
(1) Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Important
bullet_s.gif Handle ink tanks carefully to avoid staining clothing or the surrounding area.
bullet_s.gif Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
i_note_us.gif Note
Be sure to replace ink tanks one by one when replacing more than one ink tank.
4 Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
(1) Unpack the new ink tank and completely pull off the orange tape. Then, remove the film.
(2) Remove the orange protective cap from the bottom of the ink tank and discard it.
Important
bullet_s.gif Be sure to remove the clear film from the ink tank in the exact order shown in step 4-(1), as failure to follow this step may cause the ink to leak and stain your clothes and hands.
bullet_s.gif Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
bullet_s.gif Do not re-attach the protective cap once you have removed it.
bullet_s.gif Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
bullet_s.gif Ink on the removed protective cap may stain your clothes and hands.
bullet_s.gif Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5 Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the push_3.gif mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important
Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6 Close the Inner Cover.
i_note_us.gif Note
Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7 Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
i_note_us.gif Note
bullet_s.gif The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
bullet_s.gif To maintain optimal print quality, use an ink tank within six months of first use.
bullet_s.gif Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
bullet_s.gif Color ink consumption may occur even when black-and-white or gray scale printing is specified.
Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
bullet_s.gif When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Apr 03, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Replaced Yellow Cartridge, Red light on, close lid, not working,
Hi ...
I would suggest that you follow the below stesp to install the ink tank ..
. Ensure that the printer is on, and then open the Top Cover.
Note: If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2. Open the Paper Output Tray.
3. Remove the ink tank whose lamp is flashing fast or is off.
Caution: Handle ink tanks carefully to avoid staining clothing or the surrounding area. Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
Note: Be sure to replace ink tanks one by one when replacing more than one ink tank.
4. Prepare a replacement tank.
Unpack the new ink tank and completely pull off the orange tape. Then, remove the film. Remove the orange protective cap from the bottom of the ink tank and discard it.
Important:
  • Be sure to remove the clear film from the ink tank in the exact order shown in step 4, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
  • Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
  • Do not re-attach the protective cap once you have removed it.
  • Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
  • Ink on the removed protective cap may stain your clothes and hands.
  • Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5. Install the ink tank.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
Important: Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6. Close the Inner Cover.
Note: Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7. Close the Top Cover.
  • The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
  • To maintain optimal print quality, use an ink tank within six months of first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
  • Color ink consumption may occur even when black-and-white or gray scale printing is specified.
  • When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
Put in cartridge error
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and the Scan Unit (2).
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCD displays a message asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Regards,
-SHG
Dec 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
I cannot remove the printhead to install a new one , afrain of breaking somethin
1.Confirm that the printer is powered on.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover.
Nov 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
89 people viewed this question
old marine
old marine
Corne Viljoen
