Question about Sharp AR-5316 Advanced Digital Imager Copier
Gunawan i have a problem with code L6 at Sharp AR-5316, can U help me?
    Problem Solver:
  • 12 Answers
Hi Gunawan,
The error 'L6' is usually an indication of problems with the Laser Unit in the copier.
Unfortunately the unit will have to be replaced and can only be done by trained personnel.
Contact your closest Sharp Dealer for assistance.
Regards
Gavin
Posted on Oct 17, 2008
Error L6-10 sharp AR5127 Problim i dont know I
You forget to connect the laser cable to main-board.
Jan 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
TANKS, FOR YOU HELP, I HAVE PROBLEM WITH SHARP AR-5316 IS COD-L6 10
this error is a Polygon motor lock. the polygon motor drives the mirror in the laser unit. You will have to replace the laser unit or the motor/mirror unit.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
L6 sub 10
Hello sir; I'm not sure the error code can be reset or not but we can give it a try, the easiest way just turn power on and off if don't work follow following steps;
1, press "#", "interupt" "c" "interupt"
2, enter 14 then press start.
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
L6 is a fault with the laser.
To be more specific there is a set of mirrors mounted to a motor inside the laser assembly. The machine is detecting the motor is not running.
Most likely the laser itself will have to be repalced, it is also possible the main processor has failed and is not seeing the motor running.
There is the possibility of a loose connector, but that is the least likely.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Sharp AR-5316 Advanced Digital Imager Copier Logo
131 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
