Question about LG Refrigerators
MISSING CONECTOR AT BACK OF FRIDGE FOR WATER INTAKE
    Problem Solver:
  • 52 Answers
These are sold seperatly. The manufacturers do not include them with the sale of the appliance.
I bought a kenmore and the same thing happened. these are for the automatic ICE MAKERS.
you have to buy the kit to hook the line up to a water source.
The reason they do not include this kit is because of the distance the appliance is to the different water supply sources.
Posted on Oct 13, 2008
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
Nov 15, 2012 | Liebherr Refrigerators
Plumbing in water supply to fridge.
if this is for ice maker this is how its done. run the line through the floor in back of fridge to a cold water pipe. closest to where fridge sits.
  • Turn off the cold water supply to the pipes.
  • Attach a pipe clamp to the cold water pipe.
  • Screw a packing nut into the cold water pipe. Turn the packing nut until it punctures and taps into the pipe. Attach ¼-inch copper tubing to the outlet valve on the packing nut using a compression nut. Make certain the valve is closed before you secure the packing nut.
  • Attach the copper tubing to the intake connection using a compression nut. to back of fridge,
  • Turn on the cold water supply.
  • Turn on the outlet valve on the packing nut.
  • the kit should have directions with it. good-day !
    Aug 20, 2011 | Microwave Ovens
    I have connected the water to the refridgerator and have water flowing properly from the door. However, the ice maker does not fill with water. What am I missing?
    Suggest you do a good defrost, then retry. Also take note if the opposite solonoid to the water solonoid for the fridge activates. (will be found at the back of the fridge).When the ice maker requires water, it will activate the one valve at the back.
    Aug 17, 2010 | Refrigerators
    The icemaker calls for water but no water comes into it
    Starting from the start, make sure the valve behind the fridge is open. then make sure when you disconnect the tube from the intake of the refrigerator, that water comes out. Then check the intake filter on the fridge for debris. Then defrost the freezer in case the intake line froze. If you still have no water going into the ice maker, the valve is probably bad. If you post the make/model and go through those steps I'll help you take the Icemaker apart...
    Oct 11, 2009 | Whirlpool GS6NBEXR Side by Side...
    LG model GR-620RW leaking water inside at back top
    the drain hole (freezer) is blocked,
    Apr 08, 2009 | LG Refrigerators
    Stumbles and miss fires
    Or, more likely, whichever sensors got wet finally dried out. Like I said before NEVER wash engine!!!
    Mar 04, 2009 | 1991 Jeep Cherokee Limited
    Water dispenser and Ice maker not filling with water.
    You need to replace inlet valve for the dispenser and ice maker .
    Dec 09, 2008 | U-Line Refrigerator Ice Maker
    Missing car
    if your car is missing and you have a coolant leak and you coolant light is on let me the first to tell you that your intake manifold gasket is leaking , GMs finest intake manifold gaskets are made of some sort of plastic and they love to leak, especially in the 3100 v6 many probes with that intake.. as for the spark plugs in the back ,if you have front motor mounts that are accessible, remove them so you can tilt the engine foward that is the easyst way to change the back ones
    Nov 23, 2008 | 1999 Oldsmobile Intrigue
    G892-SC Miele water intake/drain light blinks
    The intake/drain light blinks. How do I fix this problem?
    Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
    Refrigerators Logo
    60 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
