My labtop sound problem
I think it was the problem with the driver. When I play the music by plug the headset, it still have in the speaker. Even webcam microphone I can't use it. I need a real driver for it because I think that the saler who sale this computer to me set it with the wrong driver. So how can I download the driver?
Thank you
    Genius:
  • 1,605 Answers
Go to control panel, sysem, hardware, device manager.
see what autio card is listed. copy the mane and model if you can, then go do a web search.
option2 is find out what make and model is the laptop and go the vendor website and download the drivers.
if that doesn't work, then My guest is the plug for the headset is defective.
Posted on Oct 13, 2008
I installed a software called Hear on my T420 laptop after a while i uninstalled it but since then i have problem with sound! when i play music i hear the sound from the speakers, it's normal but
Use the SYSTEM RESTORE utility to go back to a certain date that you think is in its perfect condition, say 2 to 5 days ago will do. Everything will be restored except data or work files. Good luck
May 19, 2012 | Lenovo ThinkPad T420 Notebook
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
My computer works great but I have no sound
try to play any music theres a sample music under the music folder
if you are getting an error message that theres no sound device available then you have to reinstall the drivers for your sound card
if you are not getting any error message, check if its not in mute
if its unmute try to use a headset and try to play music
if you are using a speaker check if the cable is properly connected (normally its plugged in to green port at the back) and its turned on , make sure that the volume is set to middle.
if still not working while its plugged in the back try to plug a known good speaker in the front port
Sep 06, 2010 | E-Machines eMachines Desktop PC
Having sound problem in my laptop after i got plug in the headset , but the sounds coming through the headset but vice versa in laptop
Go to Control Panel >> Sound >> Play back tab >> Right click on Speaker and set it default.
Connect Headset >> Play any music >> As soon as the music started, remove the headset with a slight ****.
Restart Audio services if issue is same and then update the audio driver.
Start search >> services.msc >> right pane, double click on Windows Audio >> Stop >> Start >> Startup Type: Automatic.
Update the drivers
Jul 28, 2010 | Computers & Internet
When i plug in my logitech headset whitch is usb plugin the music plays go over the headset.But when I unplug the headset music does not play over the speakers.How do I fix this so it playes over my...
Start - Control panel - Sounds and Audio devices - Click on the "Volume" tab. Check that the device volume is included in your volume control (Advvanced - Options - Properties)
Also check your speaker Volume and Settings.
May 16, 2010 | Microsoft Windows XP Professional
Headset & speaker both are playing at same time
Most probably headphone socket in the laptop is dirty. Spray some WD 40 or replace it.
May 20, 2009 | Logitech 250 Headset
I want to play a video on my mobile phone (Samsung SGH-U900V) and listen through a bluetooth headset (Motorola S9); unfortunately, the sound comes out of the phone speaker instead. The same happens with...
I think the problem is that the media player plays the sound from the speaker instead of sending it to a bluetooth headset. have a look into the media player options and settings, also try a headset or headphones that you can plug in the phone, that should work also.
May 09, 2009 | Cell Phones
Music plays through speaker when receiving messages
its tha connection from your head set to ur fone move it around till u hear it beep in ur head set then it shud play in ur head set hope dis helps
Mar 22, 2009 | Nokia N79 Cellular Phone
I think I need a driver for a Mikomi headset with mike.
mikomi head and mic set drivers for xp pro meed pls
Mar 18, 2009 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
