Question about 3M Vikuiti eXtended Resolution Video Screen XRVS-120 Monitor
Every time I log on I have to adjust my screen resolution back to 800x600
My wife and I share the same desktop pc but have different accounts. Hers is problem free, but each time I log on my screen goes blank for a couple of seconds, then comes back with huge letters, and I have to reset my screen resolution back to 800x600 even though I click "apply" and "OK" each time. Can anyone out there help, please.?
  • 3 more comments
  • Jonnyaig Oct 14, 2008
    Sorry for my lack of information required. We are running Windows XP home edition, the resolution goes back to 640x400 (if I remember correctly), I then change it to 800x600.
    Having received an e-mail advising me to "Click here" to view the solution to my problem it appears the "solution" is not Free as previously advertised but I have to pay to "Try our Premium Assistance plan".
    Obviously I am disappoiunted with this "solution".
  • Jonnyaig Oct 15, 2008
    Thanks, both my wife and I are set up as administrators and have had no problems before, hoever I will have a go at those suggestions and open a new accountif I have to, (after I have mastered the art of saving my docs and photos first), as you may be aware I am somewhat of a nerd in pc problems but I will get there eventually.
    Thanks again for your suggestions, watch this space.
    Jonnyaig.
  • spliffy09 Mar 01, 2009
    same thing-its annoying having to reset it to 1024 so i can read it-got a few sight probs so any info would help !!
  • Fran Bednar
    Fran Bednar May 11, 2010
    What operating system are you running? Does the resolution change or does the font size just change ?
    You say you put it back to 800x600. That is as low as it goes on most
    !! Or does it start at 800x600 and you want set it at something else ?
    Novelist:
  • 159 Answers
Xp should be remembering your settings:
This may not be a solution , but it is something to look at.
Check to see if you have any accessibility settings set up on your login. This can be found in the control panel.
Check to see if both accounts are set up as administrators even though this shouldn't be the cause.
If that doesn't work, try opening another account and see what that one does.
Something must be set up slightly different in yours than in hers.
Let me know if anything helps, I'm curious myself.
Fran
The email you received was probably from fixya. They offer a premium plan where others can try to help you with your problem and get a fee to do so if done in a certain time frame.
Right now you are on the free end. Otherwise you would have gotten a bunch of attempted solutions by now. Would have brought out the hounds !!
Posted on Oct 14, 2008
Hi a friend downloaded crome for me and now my desktop has shrunk but he does not know how to fix it.please help
Right click on screen ( away from icons) Select properties, settings and adjust screen resolution that is easier to read (1024x768 or 800x600)
Oct 19, 2010 | Computers & Internet
FPD1960 TFT LCD Monitor that turns on and you see the Windows Screen, and then goes black. Each time I turn it off and then back on, it repeats this pattern. All cables are securely fastened, I am using...
Windows is using a video mode the LCD monitor can't display. The cable doesn't matter in this case. It's an issue of the refresh rate and the resolution set in the system.
When the system boots, hit F8 just before the Windows splash screen would come up. Start the computer in safe mode with networking support. It should be able to come up in safe mode because the resolution will go to 640x480 or 800x600 by default.
Once you get to the desktop, go under the desktop properties. Hit Advanced. then go under the monitor tab. Make sure the monitor is defined. If it says generic display it will give you resolutions and refresh rates you can't use. If it isn't defined, you can install the driver under properties.
Finally, set the default resolution to something easy like 800x600 and try the refresh around 60-65hrz.
Jun 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
I changed resolution settings by mistake.now to change them back i cant see bottom to click apply,also same problem when i try a restoe point
OK, when you first boot up, press F8 and select VGA MODE 800x600. Then when you get to the desktop, which you now will be able to see, go to your Video card resolution settings choose for now say, 800x600,and reboot,next time at the desktop, you can change resolution more carefully this time, :) Also, make sure you check the box, to apply, the resolution settings, without restarting the PC
May 21, 2010 | Microsoft Windows Vista Home Premium with...
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
Only bottom half is shown on screen from our Benq
Try lowering the resolution of your pc to a lower amount that the Projector can handle. Start as low as 800x600 and try working up from there.
To change pc's resolution: Right click on the desktop, click properties then settings and try sliding the resolution adjuster and testing each one with your projector. wait for the projector to resync itself each time.
good luck!
Dec 23, 2009 | BenQ Projector Lamp for MP610
My computer screen got bigger
Press Control and + to make it bigger
Press Control and - to make it smaller
Nov 14, 2008 | E-Machines eMachines Desktop PC
Desk top keeps going large
There is not much that you have given us to work with here, but what i'm assuming you are describing is a resolution issue.
There are a few different resolutions that a computer will typically have depending on its age and its graphics card.
640x480
800x600
1024x768
those are the typically resolutions for a basic system, those with super graphics card can go much higher.
You first off might want to see if you just need to up the settings... you can do this by....
1. right click on any empty space on your desktop and click 'properties' on the menu that pops up.
2. click the tab that says 'settings' and it will bring you your resolutions.
3.bump it up from whatever it is set to (640x480 -> 800x600 or 800x600 -> 1024x768) then click apply.
4. a window might pop up saying it is changing your resolution and asks you if you would like to keep it the new way and it will give you 15 seconds to respond yes or no before it reverts back to the prior settings.
This should fix your problem. otherwise you may need to reinstall your graphics cards via a driver download from the manufacturers website and it should have a self-installing file that will do all of the tough work for you.
If your problem seems to have nothing to do with the possibilities I just gave you please share more details about when the problem occurs, things you have tried to do to fix it that have failed. etc.
Oct 28, 2008 | Acer Computers & Internet
Not supported mode error
Hi, boot up to an F8 and select safe mode. While there change your screen settings to 800X600.
The available resolutions in the windows operating system has to be compatble with the TV screen you are hooked up to. try lower settings first.
Thank you and god luck.
Oct 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Aug 05, 2008 | Computers & Internet
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
Computers & Internet Logo
424 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
