Question about GPS
L just got this gps 2 months ago went to check out map only seeing songs that we downloaded no maps can be found saying make sure card is put in properly, already checked that . What can l do don't no where my maps went had already saved to recent but will not open. Please e-mail me back at foxyldy49@hotmail.com
    Sergeant:
  • 196 Answers
Sounds like you have overwritten the card that holds your map data with songs when the card was not intended for it... I'm afraid if you do not have a back up of the maps on CD or your own personal back up on your computer you may have to re-purchase the maps from the GPS manufacturer that made your machine... visit there web site they may have a solution for people who have made your error that is free
Posted on Oct 13, 2008
155W Have downloaded purchased update, loaded them onto SD Card. Unit says " No detailed maps found . . ."
Have you try looking in the map area to see if it is checked...
Tools... Settings ..... Map...... on bottom of screen press Map Info
Your SD card if found should have a checkmark in it. If not put one there and try it
Nov 08, 2010 | Garmin nuvi 255W GPS Receiver
Having been advised of a map update, I tried to download it. Now my device is saying no maps found. The download didn't happen either
Not sure if this helps but worth a try, go to your GPS System settings look under Maps ...see if there is a message saying it is on your gps.... and does it need to have a checkmark in it to activate?
I'm thinking if it already had one when you downloaded the other did it place 2 maps in that area and you have to chose one of them
Oct 31, 2010 | Tomtom Maps Software
Everything went dead within 2 hours. The only thing the unit will do is display the following message. - - - - No detailed maps found that support routing. The nuvi cannot be used without them. - - - - -
I would check your map to see if it has a check mark in it.....
Tools.... Settings....Maps..... on bottom of screen Map Info.....make sure a check is in City Navigator North American NT
Oct 30, 2010 | Garmin nuvi 200W GPS Receiver
A while ago I put a larger sd card in to my unit,as i wanted to install the complete maps of the U.S.A, i PUT A uLTRA 2 GIG CARD IN, IT WORKED FINE, PUT MY GPS AWAY FOR A FEW MONTHS, YESTERDAy i put the...
Most likely you got a hot copy of the maps and it worked fine for a few minutes in the new unit. Check the course of the map because they know if they are purchased new or are being copied. Not saying you did anything wrong just saying the SD card can only be used for one unit. Contact the company and they will set you straight.
Apr 30, 2010 | Tomtom GO GPS Receiver
Hello, when I turn my Invion GPS model: gps-4v506-ius, and then seect the navigation screen, it says "map not found." It's been like that for a couple months now, HELP!!!
Believe it! if it says maps not found putting it away for a few months wont repair it Ypu need to have the maps reinstalled. possible to corrupt maps easily by a spike from car charger or even leaving unit in a hot car or starting the engine while unit connected.
Jul 28, 2009 | InVion 4v1 GPS Receiver
MAPS DISAPPEARED!
Nope it disnt wipe them out, you did possibly when you put songs and things on the same area as the maps usually the root directory.
It is inadvuisable to put music on t6he GPS unless it has an SD card slot that allows for music to be loaded separately. I am sure it dont play music when it navigates anyway, so its a bot of a gimmick and a dangerous practice to use anything but maps on your GPS. get an Ipod or another device for your music. The cars may have also been placed in the wrong folder so check that they are where they should be
Jun 28, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 710 Doesnt show all the maps
Garmin maps are married to the device they were bought for. You should not be able to take an SD card from one and have it work in another. Another point is, was the 710 already registered to someone else and never deregistered? Have your registered the 710 and does it show up on your Garmin account?
If the 710 is not on your account, Run Garmin Express (download from Garmin). Connect the 710 to your PC. Any maps that the 710 is entitled to will show up in Garmin Express. You may have to buy the map on Garmin if the 710 never had it before.
Mar 30, 2017 | Garmin NUVI 710 Car GPS Receiver
TomTom One Europe
What is happening is your map updates are being copied onto your memory card without overwriting the old maps hence you are running out of memory.
In the tomtom home browser you should be able to delete your old map before installing the new one. Make sure you have a back up of the map card before you try this though so you can reinstall if something goes wrong.
Also have you replaced the voice prompts on your tomtom? The voice files take up a lot of memory so if you have put new ones one without removing the old ones you will be wasting memory.
There is one window in TThome that lists eveything installed on yuor card so have a good look at this and see what you can get rid of.
Oct 30, 2007 | Tomtom One Europe v2 GPS Receiver
GPS Logo
50 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
