I'm trying to install FreeBSD 5.3-RC1-amd64 on IBM @server 325 with
ServeRAID 6M.
This server has dual AMD Opteron 2.1GHz and 8GB of RAM.
6 x 36GB Hard disk are configured as RAID5 through ServeRAID.
FreeBSD boots fine. But when it tries to copy files it fails saying
following error:
Panic: ffs_valloc: dup alloc
cpuid = 0
Uptime: 2m46s
Cannot dump. No dump device defined
Logic hard disk is labeled as:
/ - 1GB
swap - 1GB
/usr - 20GB
/usr/local - 10GB
/tmp - 2GB
/var - 135GB
What should I do in this case? Any ideas?
thanks in advance,
Ganbold
Rating: 0%, 0 votes
At 11:19 PM 10/21/2004, you wrote:
I installed and already did cvsup and installed world.
make installworld somehow didn't know the paths
of the following tools: btxld, dd, cp, ls. I added full path to Makefiles.
Changed Makefiles files:
/usr/src/sys/boot/i386/boot2/Makefile
/usr/src/sys/boot/i386/loader/Makefile
/usr/src/sys/boot/i386/pxeldr/Makefile
Now everything seems like working fine with 4GB of RAM.
However if I use 8GB of RAM it starts not working. Some tools like netstat,
finger, sshd is not working under 8GB RAM even
I put hw.physmem=8G in /boot/loader.conf.
Any ideas? How can I use 8GB RAM fully?
thanks,
Ganbold
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
I have problem installing world after cvsup.
make buildworld, buildkernel, installkernel went OK. I rebooted afterwards,
did mergemaster -p.
However installworld says:
btxld: No such file or directory
I searched freebsd mail list archives and didn't find any solution.
There was mentioned to go to btxld directory and make install clean.
However it didn't worked.
Any ideas?
Ganbold
Rating: 0%, 0 votes
Until this gets fixed (and it's being looked at right now), you'll need
to either reduce the amount of RAM that you have or switch to a
different controller.
Scott
Rating: 0%, 0 votes
At 03:28 PM 10/21/2004, you wrote:
Yes, it is there. When it is booting and tried to run sshd it says error
similar to error when run netstat.
It says 8G in message log.
Probably some problem related to CPU or RAM, don't sure which one.
I will do that, however I have to install again FreeBSD on it, it is broken
again, when I was trying to remove/add RAM and boot.
I will let you know the result.
Ganbold
Rating: 0%, 0 votes
How much RAM does FreeBSD say is installed?
Don't know with that one.
Allways a good idea to cvsup and build kernel and
world. This way you can optimize with -O2.
Claus
Rating: 0%, 0 votes
Thanks for all who helped me.
I followed Claus's and Scott's suggestion and reduced RAM size to 2GB and
installed FreeBSD successfully.
Afterwards I added hw.physmem=8G to /boot/loader.conf file and added RAM
back and rebooted.
It boots OK, however in the shell I can't run some commands. SSHd didn't
run, said some error.
For instance when I try to run netstat it says:
/libexec/ld.elf.so.1: netstat: Shared object has no run-time symbol table
What should I do? Any ideas? Should I reduce back RAM again and do cvsup to
RELENG_5 and
buildworld?
thanks,
Ganbold
Rating: 0%, 0 votes
RAM so you're below 2 GB. I had problems installing
amd64 on a machine with 4 GB RAM.
Then add the physmem-line before you put back the RAM.
Claus
Rating: 0%, 0 votes
but system is behaving same, crashes after trying to copy files.
It recognizes 8GB RAM correctly.
Ganbold
Rating: 0%, 0 votes
and booted rebooted.
Add the line hw.physmem=8G to the above mentioned
file.
Could you supply a dmesg, type dmesg at the console.
Claus
Rating: 0%, 0 votes
At 08:36 PM 10/20/2004, you wrote:
You mean from boot prompt? I tried to boot both AMD and x86 installation
CD. FreeBSD 5.3-RC1-x86 can't recognize 8GB RAM.
Post a New problem for IBM ServeRAID-6M SCSI Controller
Email this problem
