FixYa.com
Tags:
IBM Refurbished RS6000 / SP2: SCSI ADAPTER.
DB2 Connect EE on AIX?
By kcw573 - usenet poster
Another question:
Does anyone has DB2 Connect EE on AIX? I'd like to know how it compares with
NT platform. I knew AIX is a far better system than NT, but how DB2 Connect
perform on AIX/UNIX?
Thank you,
Jon Zhang
Get your FREE web-based e-mail and newsgroup access at:
Create a new mailbox, or access your existing IMAP4 or
POP3 mailbox from anywhere with just a web browser.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2006
Not Rated (0)
Bray
Bray - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I also wanted to use TCP/IP, and did my best to convince the MVS team.
Trouble is that DB2/MVS is frozen in at V4, and "management" won't upgrade,
so we had to use SNA.
I think it is important to note that we did *not* have any problems setting
up SNA on NT, but didn't succeed with AIX. Perhaps it's unfair to
extrapolate, although I didn't mention other problems we encountered on DB2
on AIX that we haven't seen on NT.
My personal advice (as per the original question), is that if you you're
happy with NT, then there is probably no reason to move to AIX, and
statements such as "I know AIX is a far better system than NT" may well not
be borne out by experience. [That said, the same management is insisting
that we move to DB2/AIX, although we've been using DB2/NT for many years,
with the argument that "it's more manageable" - this despite the fact they
still haven't got it working reliably!]
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
Thank you all for your feedbacks. Those are very valuable information to us.
I
very much appreciate everybody's input on this topic.
Regards,
Jon Zhang
Solution #3
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
We almost always recommend TCP/IP over SNA for this reason: you could have the
same problems setting up SNA on NT as well.
Solution #4
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
MVS / AIX shop (RS/6000 SP2).
3 AIX "system programmers" (MVS terminology for "experienced administrator")
worked on it (not including me).
Also 2 IBM-recommended consultants from IBM's local RS/6000 SP2 business
partner. IBM themselves were not prepared to send in their own staff,
claiming that these consultants gave excellent AIX support (neither of them
had any experience with SNA on AIX).
Admittedly SNA was main problem, plus security issues with OS/390. The team
also opened two PMRs with IBM, and received fixes for both. Project dragged
on for months without getting to the desired results. When I gave up they
were able to do RUOW with OS/390 password (CONNECT USING) from local AIX
logon (not from NT client). Under NT we run single-signon and DUOW over NT
clients.
I admit to limited AIX experience, and substantially greater NT experience,
this probably assisted when it came to my one-man NT install and configure
job. I also knew where to look on OS/390. It is likely that there was
limited SNA experience on the AIX team, despite one of the staff's having
years of OS/390 (CICS / DB2) experience.
I won't deny that with the proper support and knowledge, it could have been
made to work. But if somebody is starting fresh on the problem, NT is, in my
experience, a much easier road to travel, and reliability (see my original
post) is excellent.
Solution #5
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
Hi Mark,
I don't mean to challenge your experience in any way. But ... when you did the
original install, were you working with an experienced UNIX admin? Is your shop
primarily NT? Did you or the UNIX admin go for DB2 training of any kind, or was
any experienced DB2 consulting help onhand?
You may have covered all these bases, however ... I'm merely making the point
that UNIX is not NT, and that to be fair, you can't necessarily expect to just
pick up a UNIX product and be able to install it successfully with little or no
experience. I've installed DB2 on AIX many times successfully, and also had some
trials/tribulations ... but a different path through the install panels (btw ...
using "db2setup" is the way to go as opposed to db2install) ... can make a world
of difference.
Solution #6
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
I went absolutely crazy trying to get DB2 COnnect EE to work on AIX.
In utter desparation I got hold of an NT Server box, installed the whole lot
(IBM Comms Server, and DB2 Connect), and had it working within one day.
The AIX team then spent two weeks trying to reproduce my result (I refused
to invest any more time), before finally giving up in hopeless despair too.
We later set up the real production system (took 3 hours) and it has been
running reliably on NT4 for over a year at 24*6+23.
"I knew AIX is a far better system than NT". Not in my experience!
- Mark Yudkin
Solution #7
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Thanks again for the tip, Larry.
Jon Zhang
Solution #8
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
Jon,
I don't have numbers, but I can tell you for sure that there is a very prevalent
DB2 Connect user install base on UNIX. You would need to contact your local IBM
Data Management rep to explore this for you if you need references.
Solution #9
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
Hi Larry,
Thank you very much for your reply.
I guess it's not very easy to put all my questions in a very specific
fashion.
Since we are currently running DB2 Connect on NT, we wonder if the
implementation on AIX is more stable than on NT. For example: DB2 Connect
used
to cause Dr. Watsons on NT platform. Did anyone every report such kind of
system failure caused by DB2 Connect on AIX?
We are interested on the impression from the user communities that DB2 on
AIX
implementation is "stable". It's a vague question, but we are interested
non-the-less.
Additionally, we are concerned that migrating from NT to AIX would put us at
risk for newly discovered bugs, because our feeling is that the user
installed
base is predominantly NT. If you could provide us some information or ideas
on
proportion of DB2 Connect implementation that is AIX versus NT would be very
much appreciated.
Once again, thank you for your prompt response.
Jon Zhang
Z
Solution #10
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Jon, it seems to me like you're asking a pretty vague question... can you
please be more specific?
Larry Menard
IBM Workstation Database (DB2) Performance Team
Defender of Geese and of all things Natural
Can you Help with these Storage Controllers problems?
Storage Controllers
compaq presario 6000z
may processor that uses amd... Answer This...
Storage Controllers
Installing
I have a Lexmark 1200 that i... Answer This...
Storage Controllers
how do i use a memory stick
please give me explicite... Answer This...
Storage Controllers
probleme
je ne peux pas telecharger le... Answer This...
Storage Controllers
SWEEX 4 PORT USB 2.0 & 3...
Hi there, I have this... Answer This...
Repair Service
Find Storage Controller Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
