Question about Rosetta Stone Chinese Mandarin Level I & II Set Personal (chilspe)
Rosetta Stone Error 9120
I try installing the language cd but i keep getting the error saying "there was in error in the application" with the numbers 9120. Also my operating system is Mac
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Rosetta Stone Expert
  • 37 Answers
Language CD is the main problem to get error 9120. To fix this i got this link for you all Ask Question Rosetta Stone Community
Posted on Dec 27, 2014
5 Suggested Answers
SOURCE: Headset Problem Rosetta Stone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Posted on May 07, 2009
  • 4 Answers
SOURCE: After uploading the application software for
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Posted on Jan 17, 2011
  • 20 Answers
SOURCE: Rosetta stone on Mac doesn't open because of error 9120
Go to System Preferences (click on the apple in upper left corner of monitor and pull down)
Look for "hardware" and click on "sound". Is your mike on? Make sure your "output" level is high.
Hope it helps!
Posted on Feb 27, 2013
Rosetta stone 9120 on mac
You can fix Error 9120 on Mac by fixing the disk utility to repair permissions. Find the instructions at Questions Rosetta Stone Community
Jul 02, 2014 | Rosetta Stone Chinese Mandarin Level I &...
Error 9119 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure. Good luck and spread the word.
Dec 05, 2013 | Rosetta Stone V3 Spanish (Latin America)...
Error 9119 rosseta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Hope it helps!
Feb 22, 2013 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
Error 9119, 9114 rosetta stone
Dec 29, 2012 | Rosetta Stone Computers & Internet
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
After uploading the application software for Rosetta Stone, I try and start the application and I receive: there was an error in the application. error 2123. How do I fix this problem for my iBook G4...
Feb 02, 2010 | Rosetta Stone Spanish Spain Level I & II...
There is an error with this application
Nov 23, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Help, I am trying to run Rosetta Stone Spanish. I keep getting a dialog box which says: ''Object Expected Script error. Continue yes no
This error identify that the script for Spanish language is not installed or corrupted it comes in separate CD
Aug 31, 2009 | Rosetta Stone Spanish I & II Personal...
Rosetta Stone Chinese Mandarin Level I & II Set Personal (chilspe) Logo
1,488 people viewed this question
Top Rosetta Stone Computers & Internet Experts
vince
k24674
Vladimir Frolov
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
