Question about HP Pavilion ZV5000 ZX5000 Compaq R3000t R3200 series 15.4-inch TFT WXGA LCD Display-350217-001 (350217001) CD-ROM Drive
Cant start windows after RAM upgrade
I replaced the 256Mb memory at the bottom with 1GB and I can not start windows (getting the options below). I now have 512Mb + 1GB. After trying many things, I reformatted and installed Win XP SP2 again and it worked. But the next time I turned it on, I had the same problem. I get the following options when I turn it on:
1) Safe mode (OR safe mode with Networking OR safe mode with command prompt)
2) Last known good configuration (your most recent settings that worked
3) Start windows normally
whatever I try, Windows try to start and they just hang...
In the setup I can see that there is 1408Mb memory which sounds right.
  • tony_karinio Oct 20, 2008
    can you recomment a memory test? Is windows memory disgnostic test fine?http://oca.microsoft.com/en/windiag.asp
    By the way I have tried to use only one memory at a time and one memory slot at a time and I have always got the at the setup the corresponding memory size which makes me believe that there is no problem with any of the memories.
  • tony_karinio Oct 22, 2008
    I did this memory test www.memtest86.com and it was successful. I have also done a hard disk test, whch was also successful.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
Download or get a memory test utility that boots from some device (a floppy, flash drive or CD-ROM) that your PC can read. Run that test to confirm the installed memory is good/compatible. Loose memory modules and PC boards can be zapped just by touching the connector pins while you handle them. During removal or installation you have to frequently touch the machine's frame or wear an ESD strap before handling the module, to prevent this.
Posted on Oct 20, 2008
Cpu upgrade
Maximum memory for this model is 512mb, no cpu upgrade neccessary. 2 x 256mb sticks is OK.
Jan 18, 2014 | IBM ThinkPad A22p 2629 Notebook
I have got a compaq presario 6000 series pentium 4 desktop. I bought a 1GB kingston PC2100 DDR ram, 266Mhz ram for upgrade from my earlier 256MB ram. Somehow my desktop doesn't detect the memory upgrade...
the bios might be seeing it but windows might not, the possibility exists that windows is not able to view the full amount of ram installed try this. go to the start menu > accessories > system tools option and look for the system information tool, this will tell you more about the ram installed, note: windows dose on occasion report the wrong amount of ram when their is a 64 bit os installed or their is a 64 bit system
Dec 14, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Dear Sir/Madam, i am using ASUS F-80Q laptop and the graphics is GMA x4500hd Gfx, it only shared 256mb memory, but i have seen about 1gb memory can this chip share (in fujitsu laptop)... there is no...
A BIOS firmware upgrade may allow the video RAM to be increased from 256Mb of RAM. Check the motherboard manufacturer's WEB site to see if this is possible.
Oct 06, 2009 | Asrock P4I45GV R5 Motherboard
Upgrading memory on n232 motherboard
Check the specs on your motherboard from dell
Jul 26, 2009 | Dell Computers & Internet
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Error after memory upgrade
the frequency of 256mb ram is nt equivalent to one gb ram
Jun 20, 2009 | Dell Dimension 2400 PC Desktop
I need to add extra memory now my lap top works with 128 MB i need to be 256 MB
thats no problem sir,u can upgrade the memory cards of the computer to the level which it supports may be 1gb,2gb or 4gb.....
u can purchase another memory stick of same specifications because its availiable is different size like 128Mb,256Mb,512Mb or 1Gb.....you can use any one according to your wish...
Apr 26, 2009 | Toshiba Tecra 8200 PIII-850MHz/ 256MB/...
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Computers & Internet Logo
205 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
