Question about Panasonic CS-A12C Air Conditioner
Air con model no CS-1273KR
I would like the manual for the remote to set the time and understand all functions
Okay, the question WAS asked just over six years ago, but I see that it hasn't been answered yet:
To set the time:
1. Open up the "door" in front of the remote.
2. Press the little round button beneath the "UP-DOWN" button.
3. Set the time using the ?P-DOWN" button.
(How I know? I double-checked it with my remote, which is an A75C377).
The manual does not show you how to set the clock; only how to set the time. Manuals are available online - do a Google Search...
Posted on Jan 17, 2015
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
lenwest
  • 150 Answers
SOURCE: Remote's functions dont control the air con anymore.
Have you checked the battery's in your remote?
Posted on Jan 30, 2009
SOURCE: Panasonic AC Model CS-A28BKP5 remote not working.
order new remote
Posted on Mar 14, 2009
  • 52 Answers
SOURCE: Fujitsu Reverse air con not blowing heat anymore
Reverse setting could need checking here sliding valve could have siezed. you would need a service Technition. your default setting is working fine so it needs to be checked on heating mode function.
Posted on Jun 09, 2009
  • 45 Answers
SOURCE: electra remote wont work with electra air con.
hi.you should have a sticker under the indoor unit head unit or on the side.
Posted on Jun 10, 2009
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
Panasonic AC Model CS-A28BKP5 remote not working. Remote does not work....Replaced with a new remote however still no joy. Checked remote and is functioning correctly ....unit can be turned on and off...
If receiving signal in unit and calling signal in remote should be functioned properly. If any one of these, defective you can't operate by remote.
In your case, it's receiving signal in PCB is weak or defective. You can repair/replace only that portion. Call repairman to arrange for it. Thanks. Helpful?
Jan 20, 2011 | Heating & Cooling
I cant get cooling from my air con,model-emailair WS066H,but I do not have a remote control for it,can i control it manually.
Only in some models, there is an option to operate manual. Check near indoor display. If there is button press it. But you can't change temp setting and mode as you like.So, It's advisable get new remote.
Dec 29, 2010 | Heating & Cooling
I have an old Kelvinator air conditioning. Not sure what the model is since I have lost the manual, but from the remote control I can see some code looking like the model number: 6711A20012M. A few weeks...
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
Dec 25, 2010 | Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
I NEED TO SET THE AIR CON UNIT TIMER BUT DONT HAVE THE MANUAL? CAN YOU PLEASE LET ME KNOW HOW TO DO IT? ref no:- ASYA18 LCC WALL MOUNTED AIR CON UNIT
Simple! First set the time, if it is. And press timer on and set the time and same to timer off. If no time function, press timer on it will show 00.30 to 24.00 hrs. Set as per your need.
Dec 08, 2010 | Fujitsu Heating & Cooling
Not Cool
Measure room and calculate btu's
Formula Length times Width times Height Times Eighteen divde by Five.
Example: 12 x 15 x 9 x 18 / 5 = 5832 BTU's
Jun 03, 2010 | Panasonic CS-A12C Air Conditioner
Jan 30, 2009 | Heating & Cooling
Heating & Cooling Logo
209 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
