Ariston Technologies L63SNA Stainless Steel Built-in Dishwasher
Problem for Ariston Technologies L63SNA Stainless Steel Built-in...
Ariston diswasher trips out as soon as door closed
By adamMK on Oct 13, 2008
I have an Ariston K-LS 45/50 UK integrated dishwasher that trips out the mains switch as soon as I shut the door to start running the program. I don't know how old it is, as it was here when I bought the house 3 years ago, but is this a common/known fault?
This may be nothing, but the heater element is coloured brown for the first 6 inches from the point it emerges from the bottom of the bottom of the machine, while the rest of it is the "normal" greyish silver colour
Thanks in advance
Adam
Comments:
Oct 20, 2008
- Hi,
Thanks for that. I got round to looking in to the problem this weekend and it turned out that one of the ligh bulbs in the push button board had perished to the point of falling apart; this meant that on closing the door it caused the two connections to short out on each other and trip out the electrics
Thanks for the advice
Same Problem
Apr 03, 2009
-   On an Ariston AFA370X I have the same problem with it tripping out the house fuse box when the door is shut. As far as I can tell all the front panel lights seem to be working - but I'm not sure.
Neil M-   Neil Mars
Best Solution
posted on Oct 13, 2008
Helpful)
abhishek33
Rank: Wiz
Rating: 75%, 449 votes
hi On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies L63SNA
Questions and Unsolved Problems for Ariston Technologies L63SNA
Do you recommend Ariston Technologies L63SNA Stainless Steel Built-in Dishwasher?
Answer
Answer
burnt wire on power board and doesn't go anymore. It is L63, wondering if its worth fixing
Answer
Why is it always asking for "Softner"? We keep loading it w/ more & still, the... (More)
Answer
replacement motor,where i can get replacement motor
Answer
S light flashs and two G lights flash from first and third from left
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ariston Technologies L63SNA...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
