Question about HP Photosmart 3210 All-In-One InkJet Printer
Hp photosmart 3210 vista drivers - HP Photosmart 3210 All-In-One InkJet Printer
  • Anonymous Dec 24, 2008
    Won't print. Message states " Ink system failed. Printer documentation error (Oxc 19a0013)
  • gayle1838 Jan 27, 2009
    I am trying to download a driver for my HP phoetosmart D5360 and I get a critical error message just before it finishes installing
    Scholar:
  • 136 Answers
Just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
thanks.
Posted on Oct 13, 2008
5 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
cene765
  • 787 Answers
SOURCE: My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Oct 07, 2009
pineworks
  • 4041 Answers
SOURCE: hp photosmart 3210 error oxc18a0206
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 13, 2010
I need you support to windows vista for print hp photosmart C3100 series
This driver should work for your printer in Vista
ftp://ftp.hp.com/pub/softlib/software10/COL18375/mp-47462-2/AIO_CDA_Full_Non-Network_enu_NB.exe
Robert from Blitware
Jul 08, 2010 | HP Photosmart 3210 Printer
Running Vista and printer will not talk to cpu, I downloaded drivers and reinstalled all 3210 software please help!
chek ur printer driver whether it is compatible with windows vista or not go to hp website and download the proper driver update for vista.
Sep 07, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210 scanner won't work when I installed it on my new computer (Vista). It worked on old computer (Windows XP)
u can download driver from this link for ur hp photosmart 3210 scanner . just click on link and click on download only and save into ur pc.after downloading the file u can run and install
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47754-1&lc=en&dlc=en&cc=us&product=439488&os=2093&lang=en
Jul 28, 2009 | HP Photosmart 3210 All-In-One InkJet...
My printer will not print. It says can not start printer check configuration. My laptop is a vista. printer is hp3210 photosmart
Check the connections. Does the Vista recognize it? If it does, reinstall the driver. Its a maybe that the driver on the installation disc don´t work as well, get the driver from the HP site specifically for Vista.
Jul 21, 2009 | HP Photosmart 3210 Printer
The software disc supplied with my printer does not support Windows Vista which is installed on my laptop. printer is:- HP Photosmart 3210 All-in-One. S No MY 5BB218X(Q5841A)
Is the Vista is 64 Bit? since it require Digitally Signed drivers for install any device.
And your Photosmart 3210 All-in-one.
Try This link and let me know if the problem still persists.
HP 3213 All-in-One
Nov 01, 2008 | HP Office Equipment & Supplies
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47754-1&lc=en&cc=us&dlc=en&product=439488&os=2093
Check to make sure you don't have "HP Director" under your start menu. The link above has the full package of windows vista drivers, which includes the scanner drivers.
Apr 12, 2008 | HP Photosmart 3210 Printer
Photosmart Essential Lockup
Hey guy don't follow thier suggestion. No one can't do anything for u r problem because Your H.P. inkjet Printer 3210 doesn't work with Vista. I am also faced same problem. It is technical problem. Just change your vista or Printer
Jul 02, 2007 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 All-In-One InkJet Printer Logo
1,450 people viewed this question
Seeker5211
Seeker5211
