Question about Samsung SyncMaster 940N Flat panel Monitor
Samsung Synchmaster 940N fault
Hi, My Samsung Synchmaster 940N has a problem same as one you recently dealt with. It only comes on for about 2 secs and then goes off. When you press the blue on/off button back on, it comes on again for two secs and then goes off and so on.
I notice that you had a query the same, do you know what that fellow ended up doing with it. Mine is barely 12months old. I bought it new off Ebay and notice that Samsung do not give warranties for auctioned items.
  • afmutw Nov 07, 2008
    I have exactly the same problem. Did you find a solution? Did you find the backlight inverter?
I've had the same problem with mine and just fixed it (well, it's still working now, so fingers crossed).
The problem is the high-voltage supply to the backlight is breaking down due to a discharge path somewhere.
I took my monitor apart and noticed there was a lot of residue on the underside (surface-mount) side of the power supply board. The residue was bad enough to see fingerprints in it from the assembly workers. I cleaned the board thoroughly with isopropanol (other flux solvents would probably do a similar job) let it dry thoroughly, reassembled it and since then I've no problems :o)
The monitor isn't easy to take apart. Unplug the mains supply and video connector and remove the three screws and the stand. The body of the monitor is held together with clips all the way around. Prize these apart with a penknife or similar item. You have to be fairly firm, but careful not to slip and damage the monitor or yourself. Once the back is off keep the LCD face down in the front bezel, You'll see a small cable carrying signals from the front panel buttons. Remove the tape holding the cable down and unplug the connector on the end by holding down the latch.
There's a thin shiny panel clipped to the side of the pressed metal covering for the power supply. Prize away the clips on the outer edge first, then you are able to swing the panel towards you and unclip it from the other two locations by the arrows. Underneath are the backlight connectors. Note the colours of the wires (blue near the top, pink near the bottom for both pairs) and unplug them, holding down the latch. The only remaining anchor for the panel is the flat cable connector going to the LCD driver board at the top. Angle the metal pressing up a little so you can reach the connector and press in the two latches at the side. Then just slide the connector out.
Now you can remove the pressed panel holding the power supply and the VGA connector board. Undo the screws and take out the power supply board. Disconnect it from the other board (remember the latch) and pop out the three pegs holding the supplementary insulation sheet onto the back of the board. Don't lever them from the caps, just press the latching ends inwards and they pull out easily. Now your board is free you can inspect it and give it a clean. If anything looks damaged on the board it's probably best to replace it. Otherwise if it's covered in sticky residue like mine, clean it using a clean stippling brush or and old dry toothbrush with plenty of solvent and let it dry for a while.
Reassembly is just the reverse of assembly.
Hope I didn't forget anything. Good luck if you want to try it, but if you're not confident with electronics find someone who is. There are probably a number of faults that could result in this symptom, and I don't know how common mine is.
Cheers
Posted on Nov 08, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Go & buy new backlight inverter. change your inverter.
Posted on Oct 19, 2008
Samsung external monitor turns on briefly then goes black
Most likely it is a fault with the external monitor, either an inverter circuit board or the CCFL lamp.
To confirm if the laptop video card is faulty, connect another external monotor to the laptop and if the monitor is OK then it confirms the Samsung monitor is faulty.
Mar 31, 2012 | Computers & Internet
Hi. I have a samsung syncmaster 940n black. After i turn on my computer the screen if just black and the blue light(where i turn the monitor on) just blinks.It worked normally yesterday.
The most common problem with the 940N units is a failure of the power supply/back light inverter board. This is easy to repair be replacing 6 capacitors on the power supply. Here is a link to a repair guide with dis-assembly instructions and what to look for and replace and the power board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 17, 2011 | Samsung SyncMaster 940N 19 inch LCD...
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Facebook display problem Samsung SynchMaster 713BM monitor
it must be the drivers your using for the monitor. Have you checked the pins connector are all straight. as bent pins will cause this.
http://www.howtodrivers.com/model502115.html
webpage link for drivers
AndystUK
Vote me happy
Aug 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
Screen goes black after 2 seconds
Simplest solution may be the screen resolution settings are set higher than the monitor's capabilities. Try lowering the screen resolution and refresh rate in the display properties or try booting to safe mode (press F8 when the Windows splash screen first appears) and see if the LCD will display the windows desktop. It that works, check your video drivers and the screen resolution and refresh rate settings.
If the monitor has the problem in safe mode and/or if lowering the screen resolution and refresh rate don't help then I suspect the a problem similar to one some Dell 17inch LCDs have. On the Dells It is usually caused by a defective voltage regulator transistor in the backlight inverter circuit. Troubleshooting that problem should only be attempted if you have experience at repairing electronic circuitry since it will involve testing individual components and soldering.
Jun 15, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Samsung SyncMaster 940N Flat panel Monitor Logo
2,536 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
