Question about Dishwashers
Teka Dishwasher DW6 59 FI Electronic. Stuck on rinse and will not operate on any programme
    Genius:
  • 1,239 Answers
Hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 13, 2008
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Hi my teka dishwasher dw7 56 fi makes a noise when first switched on .
what is it supposed to do . be so quiet you can not hear it working .
Dec 07, 2015 | Dishwashers
How do I fix a Teka DW6-59 dishwasher thermostat problem
If it heats and fills, would not think thermostat, tstat checks that the temp is ok, then prog moves on, If tstat, would never move on. think more after that, maybe, does the pump work, could be broken wire power to pump, can you hear the pump working, if continuois cycle, at what point does it stop and start at beginning, does it pump water out? if not water level sensor.
Jul 29, 2014 | Dishwashers
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
Need an english manual for teka dishwasher dw6 59 f1 please
By maggiegardne on Nov 20, 2010
need an english manual for teka dishwasher dw6 59 f1 please
Nov 20, 2010 | Dishwashers
How do u clean the pump and drain hose on a teka dishwasher? please help
buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
THis should help clean the pump and drain hose.
It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
I tried this site
http://instructionsmanuals.com/lista2-20-49-en-Dishwashers-Teka.htm
but they all seem to be in European languages.
May 25, 2010 | Dishwashers
How to reset a dishwasher teka lp700
i have a problem with teka lp 700, dial gets stuck and water starts to spill out, also the motor after awhile ceases up.
Apr 19, 2010 | Dishwashers
Hotpoint Dishwasher. The spray arms are not operating.
clean holes in spray arms may be good to clean pump also
Aug 12, 2009 | Dishwashers
Fagor f1-48w
The machine won't go into rinse if the rinse isn't hot enough. Check the thermal trip hasn't operated and that the thermostat bulb us fully inserted into the pocket in the front of the boiler.
Jul 02, 2008 | Fagor 24 in. FI-48W Dishwasher
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
Dishwashers Logo
2,884 people viewed this question
Top Dishwashers Experts
