Question about Bosch Washing Machines
Error code on bosch washing machine wwwf 2000 3 flashes of prewash light
    Genius:
  • 1,239 Answers
HI
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Oct 13, 2008
  • ABHISHEK.C
    ABHISHEK.C Oct 19, 2008
    hi
    sorry sir i sent you a mislead information that i have to send to other customer your vote changed my ranking please change it please......................
Electrolux washing machine wh1092 when turn on lights 1,4 and 8 flashes. Nothing happens
If I understand correctly there is blinking LED-s from "Prewash","Rinse Hold" and "End of cycle". In binary code it is fault E91 what means communications error between main PCB and display board.
So, could be: main electronic PCB, display board or wiring.
Dado
Dec 13, 2014 | Electrolux Washing Machines
Bosch wfl 2000 problem
it is not doing what it's supposed to do.
power is not routed properly - replace the board
Jun 13, 2008 | Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The prewash light sometimes comes on in my bosch washing machineo
I think you should concern with the manufacturers of this company because concerning someone might be risky. UK Academic Writers
Jul 25, 2017 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
129 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
