Question about NAD Televison & Video
I have a NAD3240PE, which I have had for many years from new and don;t want to throw it away because its such a good amp. It just stopped working after 27 years(?, when I power the unit up, there is thud on the speaker output, but nothing else, the power light does not come on. I would like to take it to a service shop, but the one that I have used for years ahs closed down, I live in the UK
fairlane
  • 50 Answers
SOURCE: Panasonic DVD-RV32 DVD Player-No image on RCA output
Hi Obviously the unit is playing the disk because your audio is fine, and getting some kind of black & white picture out of the composite, means that the video processor is probably ok. The most likely things to check then is the yellow video cable, (just swap the red or white in place of the yellow on both the DVD and your tv to test), or possibly the yellow RCA jack on the back of your DVD has gotten loose. If you have not done so, try wiggling it gently to see if your video comes back. If it does, and you are handy with a soldering iron, you can probably repair it yourself. Other than that, it would be a problem for a repair shop. (and a strange one!) Hope this helps, and good luck!
Posted on May 18, 2007
  • 83 Answers
SOURCE: No Output from amp, green LED on
are you absolutely certain your subs are in good shape? have you put a meter on them and measured the ohms as you depress the cone [causing the cone to move up and down on the pole of the magnet? do the ohms stay constant? go up to infinity[ suggesting an open] or go to zero or close to zero [ suggestting a short] both of these conditions will result in a zero or a very limited output from your amplifier, while still showing a green status light, if or when a full short or open occurs on the subs, a fault led will become lit, and whet that means is that u have fried the outputs....do a bit more testing with your vom....and good luck or try another speaker for testing purposes...
Posted on Jun 30, 2007
SOURCE: No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Posted on Aug 17, 2007
DrElectrics
  • 199 Answers
SOURCE: Infinity Basslink 2
Follow these instuctions and piece together where you went wrong. Sounds like a wiring fault.
http://www.ehow.com/how_5829_wire-car-stereo.html
Posted on Feb 18, 2008
  • 120 Answers
SOURCE: No audio output from a Uniden Bearcat BC-100XL Scanner
does the speaker have static when you open the squelch?
Posted on Mar 27, 2009
My dirt devil max keeps shocking me, amnd it seems to get more oomph to it. Is there a groundbsomewhere that may have un-ground somehow?
1, stop using it its dandgerous, & 2 there is a short circuit, get it repaired or throw it away & buy a new 1
Jul 30, 2017 | Dirt Devil Vacuums
I have an old Yamaha amp which has not been used for 15 years & it now keeps turning the sound on &off
If the unit has sat that long chances are capacitor replacements are in order, overtime they deform until they become unusuable and can rupture when power is applied.
Aug 31, 2012 | Yamaha Audio Players & Recorders
My car will not start and i recently changed the spark plugs but did not gap them the person told me i didnt need to so im asking you hat is the proper gap cause i think i need to gap them and replace the...
You always have to at least check spark plug gap
In 47 years, I have never seen a set of plugs that were not
knocked around & the ground electrode bent, on at least
a couple of them
You can clean a rotor & cap & get 3 years out of them,
no need to replace until they get too corroded
Wires last 15 years no problem
Don't get caught up in all the hype & tune-up non sense
The gap is on the radiator support label
The coil has to be tested,you don't throw parts at a problem
If it doesn't start, it has nothing to do with rotor,cap,plugs or wires
You could throw away 2 plugs & it would start on 6
Jul 04, 2011 | 1992 GMC Suburban
Will a 12 volt slide battery work in my 9.6 volt Black & Decker Firestorm drill. The 9.6 volt batteries don't seem to be made any more. I don't think I paid a lot more for the original drill...
This close to father's day you should be able to buy a new drill for about the same as a battery. The 12v would overheat the motor if you ran it for an extended period.
Jun 13, 2011 | Black & Decker 9.6v Cordless Drill/driver...
I'm buying a 1990 lincoln with 68,000 miles on it. Theres a problem with the power windows. The car sat for a while & wasnt driven. Could the problem be a fuse, the motor? What do you think? thanx Tom
Don't buy a 21 year old car. PERIOD
A vehicle like that, is a restoration project,
for those of us with the tools,knowledge &
lots of money to throw away at a hobby
It could be a window switch on door panel,
window regulator, window motor.
Half the windows probably each have different
issues.
That car is worth $500.00 at most
Apr 22, 2011 | Lincoln Continental Cars & Trucks
Juicer just stopped working
call or email omega url:omegajuicersdirect.com
Jun 29, 2010 | Omega 1000 Juice Extractor
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Owned NAD power amp for 15 years.
dont throw it away...i like to fix em. What model is it.
Dec 09, 2007 | Audio Players & Recorders
Televison & Video Logo
Top NAD Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Raj Patel
 Grubhead
Grubhead
Are you a NAD Televison and Video Expert? Answer questions, earn points and help others
