I am guessing it is the reverb tank. I dont know if my tank is original. What is the model number on your reverb tank? Mine is 8db2c1d.I am guessing it is the reverb tank. I dont know if my tank is original. What is the model number on your reverb tank? Mine is 8db2c1d.
You can't post conmments that contain an email address.
Nothing wrong with the amp. Google it- these amps have extremely weak reverb. All of them are the same. It's the one weak point about these amps. And I love mine. I mic it when we gig. Sounds awesome both clean and driven. But you'll have to get a separate reverb pedal if you want "girl crush" or "pipeline" reverb. Don't listen to the above posters. It's the way these amps are.
Try this website:http://tubesandmore.com/ Look under reverb tanks. Check to see how many springs your old tank has and what size it is. I think Marshall used Accutronic tanks but have a look at all of them. There are pictures and info for each. Hope this helps.
Hi chagzuki, you are right, but only when the valves are used as outputs, You amp has transistorised outputs, and a single tube used for distortion/gain. You will get a very long life out of this tube also because its supply voltage that is is used in the valvestate preamps is really quite low. Just enough for it to work really, so the tubes life can be expected to be much longer than normal. It is also a preamp tube, not an output tube, so they rarely need changing. If you ever did want to change it(dont bother), it is located on the PCB inside the unit. You have to slide the sleeve off to get at it. Get yourself a JCM800=the best guitar amp ever built(imho), then yo got pure Marshall tone, and output tubes that need changing every 6 months or so. Now go RIFF OUT and dont worry about your valvestates' "valve"
