Different sound to picture
Recorded a programme of t.v, on playback got the right picture but the wrong sound
  • tragikomik Oct 31, 2008
    I have a Zenith VCR which recently stopped recording sound on new recordings. I know that the cables are correctly plugged up. It just won't record over the sound from the previous program. I have tried many different tapes, some new, and I have cleaned the heads.
  • CharleneSG Nov 16, 2008
    I have the same problem; however mine happens when recording on one vcr and playing back on the other. If I record and watch a video on my "#1" VCR then all is fine; similarly if I record and watch a video on VCR "#2" all is fine; but if I record on VCR "#2" and playback on VCR "#1" then the video is the right show but the sound is from previous taping. Hope that made sense.....any ideas?
    Thanks
    Scholar:
  • 70 Answers
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Posted on Oct 14, 2008
Playback background noise
Undo the previous recording after each take
Dec 23, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Canon MV730i video camera records sound only, no picture. No picture on playback either.
did you recording on differant taps, does all of the dont give you picture.
try clean the head with a head cleaner and then try.
Sep 24, 2008 | Cameras
We want to connect our Sanyo VHR-795E to a recently purchased LG freeview TV to record programs. Our best efforts so far have resulted in recorded picture but no sound in playback mode. We have tried...
Some TV's have different settings for outputs at scart sockets. Read the manual on the TV to see if it mentions what the scart(s) sockets output.
However I think you might find it better to connect your VCR to a seperate Freeview box, that way you can watch a different channel to the one you are recording. Box's are cheap at the moment you can get one for around £10 on E-Buyer.Com.
Aug 23, 2011 | Sanyo Televison & Video
What does wrong format mean with a canon zr300 camcorder? My buddy shot some footage on a high end camera and my zr300 camera at playback reads "wrong format playback not possible.
Different camcorders have different recording formats. Some ar HD, some are 16x9, etc.
A camera that isn't designed for a particular pre-recorded format cannot playback that recording.
Rick
Sep 06, 2010 | Canon ZR300 Mini DV Digital Camcorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Playback Problem
open the recorder, 4 screws at each corner, wipe the playing head and the voice reccognition head, to the right of the playing head head with a baby wipe, you will be amiazed what **** comes off it. DON'T scrub it just wipe lightly, spin the playing head so it's clean. If you have a lint free cloth ( a glasses cleaning cloth you get in the case is brilliant) Try the tape (before you put it in make sure everything is DRY!) and your problem should be solved. It worked for me! and that came from a TV engineer
Jul 15, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
I recorded my professors lecture and the recorder was right next to her, when I listen back I can barely hear a thing all there is is her voice but muffled because it sounds like a loud wind
During Playback you can press + or - buttons to adjust the volume. Maybe this is your problem. If you need more info watch video instructions chapters for Olympus on http://www.HandBookLive.com under Electronics-> Audio. There are 20 different video chapters. The info about + - buttons for volume during playback was chapter 7 (Playback)
Apr 14, 2009 | Olympus VN-4100PC Digital Voice Recorder
There is no playback picture viewing a recording.
if you have the setting to avi it will not show up, you will get sound but know pic just a black screen, try the dvd setting and the the other dv setting.
Dec 03, 2008 | Ulead Videostudio 8 for PC
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
