Question about HP Office Equipment & Supplies
My HP Photosmart A620 printer makes the pictures too dark. The screen shows the pictures with normal colors but when it prints out they are all too dark. I must change the lightness of EACH picture before it can be printed out. What is the solution? I had the previous model and did not have any trouble with it at all! This is a decided disappointment. Thanks Rheba
    Sergeant:
  • 352 Answers
Hi Rheba,
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 13, 2008
New HP 95 color cartridge does not print all the colors correctly. Does not print yellow.
It could be a defective cart, but it also could be that the connections from the printer to the cart are not making good contact. Pull the cart, and gently wipe the connections with a soft cloth. Very gently clean the wires that connect, being careful not to bend them in the printer....
Oct 07, 2016 | HP Photosmart C4150 All-In-One InkJet...
My HP Photosmart 3210 Printer does not Print Red.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
Jun 08, 2012 | HP Photosmart 3210 Printer
I am printing a picture of a item someone email to me when I review this item on my computer it has a white back ground and the item is green and yellow. But when I print the picture the green part is now...
it depends, either the printer is faulty or has a modified color shceme loaded or the monitor is not displaying true colors but inhanced colors. try to first use one of the online screen calibration test to verify the colors on your monitor are correct if so then check the color scheme on the printer.
Mar 08, 2011 | HP Photosmart C8180 InkJet Printer
HP Photosmart C3100 printer is printing very slow.
Check 'properties' when printing and make sure that you are not printing at the highest quality color if you are not printing pictures.
Jan 31, 2010 | HP Photosmart C3180 All-In-One InkJet...
Even though both the color & b/w cartridge are new my print job is very light
You can try setting that darkness in your menu for set up printing. That will make it darker. If this just happened after changing the ink clean the jets before setting the darkness.
Dec 17, 2009 | HP Photosmart C3180 All-In-One InkJet...
My HP Photosmart 8150 has started printing color
You may have a colour management problem. Your monitor may need to be recalibrated from the software you are using to print your images. Your printer too may need to be sorted by calibaration too.
Jun 13, 2009 | HP Photosmart 8150 InkJet Printer
Photo prints are very dark and muddy
Hey,
I also have this problem. I even have prints that were made when I first got the printer about 2 years ago, which looked great then and now, and the EXACT same picture from the same program prints incredibly (unusably) dark.
Any help would be greatly appreciated!
Jan 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
Ink not printing the same image quality that is on computer
Issue When printing directly from a memory card, the printouts have an abnormally high red tone.
NOTE: This does not affect the prints that were originally sent from the computer. Solution Press the Photo Fix button to turn off the Photo Fix feature before printing from a memory card. Cause The Photo Fix feature was originally designed to reduce/enhance printed pictures by making colors more vibrant. However, it can also have a side-effect to make some prints have more red tone than desired. In the HP Photosmart D7100 series printer, this feature is “ON” by default.
Dec 15, 2008 | HP Photosmart D7160 InkJet Printer
Black and white printing not working
sounds like its a expired ink issue. on alot of the hp photosmart printers the ink has a expirey date on the carts the best solution would be to contact hp and chances are they will send you free carts if your ink has been expired. when a black ink is almost out most of the time it trys to draw ink from the color carts mixing to make the appropriate color.
but you can also try the following.
See the instructions for
calibrating a print cartridge in
the Care and Maintenance
section of the HP Photosmart
Printer Help.
Aug 11, 2008 | HP PhotoSmart 7960 InkJet Printer
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
