Question about Dell 962 Photo All-In-One InkJet Printer
Dell 926 all in one printer
I don't have my instruction manuel and I can't figure out where to replace the ink cartridge
  • 71 Answers
Go to this website and you will be able to download your user guide.
http://support.dell.com/support/edocs/systems/prn926/en/index.htm
Please advise if you need more assistance.
Thanks!
Posted on Oct 13, 2008
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
Oct 13, 2011 | Dell 926 All-In-One InkJet Printer
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
    Follow the below instructions
    1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
    2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
    3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
    4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
    5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
    6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
    7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
    I hope this clears up your problem.
    Good Luck and Have a Nice Day!!
    Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
    Dell Photo 926 printer will not print with the black ink and tells me that the cartridge is incompatible even though there is ink in the cartridge and i got it from dell
    Do you have a '926' or a '962' printer? You've cited each number in your problem description.
    Remove the ink cartridge.
    Reinsert the ink cartridge.
    If the problem persists, contact Dell, and get them to replace it.
    Nov 20, 2009 | Dell 962 Photo All-In-One InkJet Printer
    Dell Photo 926 ink cartridges holsters won't show up
    Contact the dell chat suport line on the dell.com website they are good at fixing probles even if they have to seend someone out or have you seend it in.
    May 03, 2009 | Dell 926 All-In-One InkJet Printer
    Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
    Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Dell 962 Photo All-In-One InkJet Printer Logo
    53 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
