Question about GE Profile Harmony DPGT750GC Gas Dryer
Heat is unpredictable
I've read your solutions to similar problems, but cannot follow a thread to resolution. I need help. My dryer is operating with heat flow that has become unpredictable over the past 2 days. I can get clothes dry, but it takes multiple cycles. Sometimes the heat comes on intermittently over a 30 min cycle; sometimes the heat only comes on for the first min of a cycle and then not again; and finally, sometimes the heat does not come on at all. There is a consistent noise that is new and is hard to describe (maybe plastic on plastic grinding). I've cleaned the ducts from the front of the dryer all the way to the outside of the house, and didn't want to go further without better instruction.
Thank you,
drakesnest@q.com
  • 2 more comments
  • drakesnest Nov 18, 2008
    Do you have a repair manual for this dryer, or further instruction? I'm flying blind here, but want to take on the challenge of fixing this myself (with your help).
    For Master_Tech:
    I've read your solutions to similar problems, but cannot follow a thread to resolution. I need help. My dryer is operating with heat flow that has become unpredictable over the past 2 weeks. I can get clothes dry, but it takes multiple cycles. Sometimes the heat comes on intermittently over a 30 min cycle; sometimes the heat only comes on for the first min of a cycle and then not again; and finally, sometimes the heat does not come on at all. There is a consistent noise that is new and is hard to describe (maybe plastic on plastic grinding). I've cleaned the ducts from the front of the dryer all the way to the outside of the house, and didn't want to go further without better instruction.
    Thank you,
    drakesnest@q.com
  • drakesnest Nov 20, 2008
    If you are an expert in software, computers, etc., please do not offer a solution. I need a large appliance expert.
    Can you provide more instruction? If it is the blower, what should I know before removing?
    Sergeant:
    Champion:
  • 324 Answers
Gas valve coils sound like there breaking down when they heat up.
Posted on Nov 20, 2008
    Scholar:
  • 157 Answers
Hello drakesnest, From viewing the replys you have and notes to efforts you have applied I suggest checking the venting to & from the unit. A extensive 'Preventive Maintance' could solve the errors. #1- close the gas line to the unit. #2-disconnect the gas line and exchaust duck. #3-move the unit to access of an air compressor, layunit on the side & blow the insides out. #4-check the wings in the drum for leaks. #5- good luck.
    President:
  • 1,952 Answers
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
    Sergeant:
    Champion:
  • 283 Answers
HI,
1.If you have problems with a gas dryer, it is very important to first check for gas leaks to minimize your risk of fire, explosions, or prolonged exposure to gas vapor. Always turn off the gas before attempting a repair even if you have confirmed there are no leaks. Electrical components have the potential to form a spark upon disconnect which will ignite the gas.
2. Never attempt to repair a faulty gas valve. This is a "replace-only" dryer part, and attempts to rig the valve may result in fires or explosions once the gas is on.
3. As with any appliance that uses or generates electricity, always wear rubber soled shoes, avoid puddles of water, and grip only the insulated ends of your tools.
Please dont rate me if not satisfied.
Thank you..
    Top Expert:
  • GE Master
  • 77,499 Answers
There are only 2 things that cause this issue, one is the electronic igniter for the gas burner, the other is thermostat that is located in the air stream, these parts are cheap and easy to replace.
  • yadayada
    yadayada Nov 20, 2008
    Most of the responding experts are guessing on what's wrong, or way over complicate the fix, why because they are fishing.
  • 1,543 Answers
I've run into the intermittent heat problem before on this unit and it turned out to be the coil on the gas valve. Unfortunately, the coil is not available as an individual part, but only as part of the entire gas valve. You can get a new valve and just switch out the coils to make your job easier. GE part number for the gas valve is WE01X10201 . This unit is actually manufactured for GE by LG, and the LG part for that would be 5221EL2002A which would save you at least $25 over the GE part number. (the box from GE will likely have the LG number on it too) It is possible that the inverter board is bad, but not as likely. Noise sounds like you will have to check out the blower wheel to see if it is rubbing.
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 20, 2008
    If you need advice on disassembley, let me know and I'll be happy to assist.
  • 4,806 Answers
It is either the heating element or the thermostat which is faulty, in most cases this is the thermostat that has developed a problem. here is the link for the user manual and troubleshooting tips: http://www.ajmadison.com/ajmadison/itemdocs/PDF_GE_DPGT750EC_01user.pdf
I hope this helps
regards
    Brigadier General:
  • 6,966 Answers
Initially, you made three (3) significant descriptions:
  • operating with heat flow unpredictable and therefore heat comes on intermittent
  • dry, but it takes multiple cycles
  • consistent noise that is new and is hard to describe (maybe plastic on plastic grinding).
Based on the above, a few ideas to explore:
  • heat production/flow intermittent/unpredictable - suggests a blower motor failure or its controller;
  • insufficient heat - heater works but cuts out early
  • noise - blower motor or its vanes blades scraping against something.
Summing the three above, probabilities forwarded:
  • the blower fan or its controller is faulty;
  • the hot air is not moving across and as fast as it should be
  • this cause heat to be localized in one area other than the clothes to be dried;
  • thermostats sense heat built-up (built not where it is wanted (clothes);
  • cuts gas supply to lower heat.
probable conclusion:
images of the units exloded parts diagram maybe found here, here or here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 18, 2008
  • Louie  Role
    Louie Role Nov 20, 2008
    The blower motor is on the bottom of the unit, at the very rear. Depending on the version that you have, the kick panel has to be removed to gain access.
    Incidentally, another some experts have forwarded alternative views. It would be to your advantage to consider their views as well.
    The exploded diagrams should give you an idea of parts location.
    Genius:
  • 1,011 Answers
Sir,
click this link for more info
thanks
Posted on Nov 17, 2008
    Scholar:
  • 124 Answers
Hi, it sounds like the problem is coming from either the ignitor or the heat sensor. I would replace the ignitor first. If that did not fix the problem, I would then repalce the heat sensor. Since these two parts work together, its hard to determined which is the fault, unless you know how to use a multitestor.
  • GE Master
  • 19,396 Answers
That is probably a faulty gas valve or the thermocouple that controls the valve is faulty.
"Drying" pipe blocked
If you can reach either end, remove it and clear blockage with wire or similar. Shouldn't stop the heating up though. Its a condensing hose that cools and condenses steam. Check the current draw with the dryer in operation, and see if there is a safety klixon in the heater circuit.
May 19, 2012 | Washing Machines
Cold air from my tumle dryer. I've taken off the back of my Creda TCR2 and the elements look fine - not tested the wiring but was wondering where the thermostats were as I've read that you are...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
No heat on kenmore 97272100 dryer
The following link explains how to troubleshoot as dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, double check your voltage at the wall receptacle. If incorrect, this will also cause the symptoms you describe. The reason: The drive motor only requires 110-120VAC to run, while the heating circuits require the full 220 service. If you are missing one leg of your 220 service, the heating circuits will not operate, but the drive motor will still run.
Next, pay particular attention to the section that discusses proper dryer ventilation. Most dryer heat related problems are attributed to poorly/imporperly installed dryer exhaust vent ducting, or a dryer that is clogged with lint preventing proper air flow. If left in a clogged condition, a dryer will actually overheat to the point of failure and you will experience repeated failures of any components you replace.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Jun 22, 2009 | Kenmore 63942 Dryer
Dryer will not heat
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Jan 22, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not heat
Jan 22, 2009 | Dryers
Kenmore model 76712 does not blow heat just cold air
Jan 22, 2009 | Kenmore 75962 Gas Dryer
Unpredictable heat
hi i think you have problem with thermostat. t hermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2: If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
thank you .............please rate it
Nov 18, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Timer runs but dryer has no heat
Okay...the following link will give you the steps necessary to diagnose and/or repair an electric dryer with a no heat problem:
Read the bottom of the link first. Verify your receptacle voltage is reading 220-240VAC. If you're only reading 1/2 the voltage you could be missing one leg of the 220 service. This will still enable the dryer to run, but the heating circuits will not operate. The reason is the drive motor only uses 110-120VAC, while the heating circuits require the full 220. If this is the case, a receptacle repair is required. Unless you are savvy with electricity, I would only recommend this repair be done by a certified electrician. If you're source voltage at the receptacle is good, then I would assume you have an internal component problem.
Read the section that discusses proper dryer ventilation. If the dryer vent ducting is clogged anywhere, and left in that condition, to dryer heating circuits will actually overheat and result in premature failure.
I hope you find this information helpful. Let me know if you require further assistance.
Nov 14, 2008 | Whirlpool Dryers
Dryer not heating
The following link explains how to diagnose and troubleshoot a dryer "no heat" problem:
Please read through the link I provided you thoroughly. There are several components that can cause a no heat problem. First and foremost, make sure you have the proper voltage at the electrical outlet. You should be reading 220-240VAC at the receptacle. If part of this voltage is missing, the dryer will still run, but will not heat. That is because the heating circuits require 220VAC to operate, but the drive motor only uses 110-120VAC. Let me know if you require further assistance. I hope this helps.
PS If you ask for further assistance, please provide your MODEL number (located on a nameplate around the door opening) as all dryers are not contructed the same. This can make a difference in where the components are located, and how to take the the dryer apart.
Nov 12, 2008 | Kenmore Dryers
Dryer not heating up
Hi Mally Try the following thread - http://www.fixya.com/problems-solutions/t103658,p117053/Bosch-Dryers.aspx It might also be relevant to your problem. Another pointer - - There might be a heat-sensitive fuse in the exhaust section of the dryer. The fuse is designed to turn off the heater element if the exhaust temperature gets too high. If this fuse is defective, it will keep the heater element from getting current. Good luck!
Jun 22, 2006 | Candy CNW156 Front Load Washer / Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
97 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
