Question about Sharp AL 1631 Copier
Error Code L
This error code "L" flashes while the machine turn on. It cannot copy anything at all, the scanner did'nt even move. What can I do to solve this problem?
  • 2 more comments
  • finoelwosr Oct 14, 2008
    Yes, this problem occurred after a power outage. Please let me know how to fix this problem
  • Anonymous Nov 18, 2008
    loud wood ****** noice
  • Anonymous Mar 09, 2009
    when I power up my al1631 copier I get an error code of L and the copier will do nothing
  • Anonymous Mar 22, 2009
    the machine did not pick up the paper to make the copy,
    my copy machine is one AL 1631
On the underside where the copies come out there is a lock for the scanner for moving purposes. Move to unlock.
Posted on Feb 16, 2009
Error L can not do anything We had power outage then this happened
Posted on Oct 13, 2008
2 Suggested Answers
babaprithi
  • 372 Answers
SOURCE: We have canon ir2000 Once when
i cant get ur problem .it might be due to home sensor problem.try to use a air blower to blow the optics unit for dust . if that doesn't solve the prob then u have to call a tech as ur scanner may be out of home position and a tech will be needed to solve that
Posted on Jun 01, 2011
F2-40 repeatedly on a new Sharp MX4110 machine
during setup the machine do,nt install toner during calibration 25-2 steps: 1. Execute Simulation 25-01 and verify that the TCD_K value is less than 26. 2. Execute Simulation 7-1 and highlight [DV Check Disable]. 3. Open the Doc Feeder. 4. Place a piece of white paper in the lead edge area of the platen glass covering about 1-2 inches of the lead edge area of the copy. This will prevent jamming in the Fuser Unit. 5. Run 50 sky shots. 6. Check Simulation 25-01 and note the TCD_K value when it stabilizes. 7. Repeat steps 2 through 6 until the stabilized TCD_K value of Simulation 25-01 is 40 or higher. 8. Execute Simulation 7-1 and verify that [DV Check Disable] is not highlighted. 9. Hit CA and make sure machine comes to a ready state. 10. Turn Machine off/on. Make sure it comes to a ready state. 11. Make a copy and check the copy quality. 12. Run Copy Quality adjustment 12a according to the service manual if necessary. Note: TCD_K value of 26 or less will cause the MFP to display F2-40 error code. Remember that the TCD_K Value is inversely proportional to the Toner Concentration. If the TCD_K Value is stabilized at 40 or higher, then the F2-40 error code will not appear. Once you recover from the F2-40 Error Code, the MFP's Process Control will take over and regulate the Toner Concentration.
Sep 13, 2012 | Sharp "MX-4100N Copier, Printer, Scanner...
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
Error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Jul 15, 2010 | Sharp AL 1631 Copier
Copier flashing error message
You did not provide the make and model of copier but this code is common among Sharp AL series copiers which are sold under various models. I have pasted my tip on the solution for this code so it should work for you.
Apr 13, 2010 | Toshiba e-Studio162D Copier
Error code "L" & "1"
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
Jul 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code definition
All I can offer is From Canon:
Problem :
The machine displays an error code of E220. The code only displays when copies are made off the glass. Originals copied using the Document Feeder do not cause the code to occur.
Solution :
Unplug the copier and remove the Copyboard glass. Move the scanner manually and check to see if the Scanner Home Position Sensor Flag is coming into contact with the Inverter Pcb, or any of the wiring. Contact with the flag may be causing a short during Scanner movement when copying from the glass.
Problem :
Error Code E220-0001 occurs after replacing the Lamp, Inverter PCB and the Reader Controller.
Solution :
Check and verify the 24V supply to the Reader Controller from the Main Power Supply (Switching Regulator) is present. It is possible that one of the loads on the DC-Controller can take down the 24 volts. Remove the 24volt loads off the DC-Controller and connect the connectors one by one to locate the short or defective load.
Apr 14, 2009 | Canon imageRUNNER 2200
Error 2200 on Dell all in one Photo 944
Honestly if dell told you to get a new one then that is what you should do.
Apr 09, 2009 | Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Error code 5010
I got the error code 5010 today (scanner lock switch). I called Canon. The printer's electrical circuitry (brain) needs to be refreshed. This is similar to wireless routers and other devices. They directed me as follows: 1. power OFF the printer 2. Unplug the printer's power cord from the electrical source. 3. Wait AT LEAST 1 minute - no less than 1 minute. 4. After 1 minute, plug-in the printer to the electrical source. Turn on the printer - wait for it to warm up as usual and it should be ok. Mine worked perfectly after the above steps. - Hope this helps.
Jan 12, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Sharp AL 1631 Copier Logo
233 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
