Question about IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop
FAn problem I have a major fan problem, i recently tried to take aprt my Nidec Beta V CPU fan, unfournately i think i might have bent the motor cause though i put in some lubricate there is still a high whrrrrrrrrr noise coming from the fan. i do not have money to buy a new one,so is it possible to replace the fan with another from my HP 2550l laserjet printer?
    Scholar:
  • 136 Answers
I really doubt it. The printers run voltages up to 30 volts, and the rpms could not be enough to cool the CPU, which could overheat and be damaged or get its life shortened. And you would be sealing your printers doom.
Posted on Oct 14, 2008
2004 Honda Accord A/C Blower Motor Make Noie !!!
When you hit the fan, one or more of the fins got bent, this will cause it to spin out of balance. The only way to fix this is replace the fan.
May 27, 2009 | 2004 Honda Accord
Monitor shuts off of the computer then stays on then goes off .
Does it shut off with absolutely no warning sounds whatsoever?
Do you ever hear a faint PC beeper alarm that kinda sounds like a ambulance siren (you know... kinda like a WEEEE. ORRRRR... WEEEE... ORRRR)
My main suspect at this stage is OVERTEMP (you are overheating the CPU).
Possible Causes: Recently UPGRADED components (especially VIDEO)
Build up of dust in Case and CPU heatsink and GPU heatsink or CPU fan has failed or one or some case fans have failed.
Do you know how to check your CPU temp in BIOS? If it happens again check it out.... greater than 90 degrees is usually bad.
Check all your fans are spinning, check you don't have 'caked up' dust on your heatsinks.
If you have recently upgraded a major component that is dumping heat into you case... investigate a new case fan to extract this heat (cheapest option) or you may want to pick up an aftermarket CPU heatsink and fan (Thermalright FTW!!!!!!!)
Mar 22, 2009 | Computers & Internet
Dell E521 computer, AMD Athlon? 64 X2 Dual-Core 3800+
If you go to Yahoo and search in shopping you can find the exact same one in there and just decide on which price you want to pay. Here is what I searched and found.
http://shopping.yahoo.com/search;_ylc=X3oDMTEwNTByOW5sBF9TAzI3MTYxNDkEc2VjA2ZwLXRhYgRzbGsDc3Bpcml0?p=Nidec+TA450DC&fr=fptb-msgr&toggle=1&cop=mss&ei=UTF-8
Feb 28, 2009 | Dell (6F858) Cooling Fan
Paslode angle finish nailer the fan wont run nor will it shoot
have had the same problem! started with a noisy fan then a non responsive one. try taking out the fan assembly as per service and drop a couple of paslode lube drops along fan shaft and gently compress fan to lubricate bearing, may not be a lond term fix but hasnt stopped since and that was over 2000 2inch ago. good luck.
Feb 27, 2009 | Omega Paslode 901000 Impulse Cordless...
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Power turns on and off
Sounds like a thermal issue. New power supply might be overheating the cpu causing the thermal sensor in the cpu to automatically shut down so the cpu doesn't fry. You could try adding a case fan or two plus upgrading the spu heatsink/fan. Hope this helps.
Dec 19, 2008 | EliteGroup ECS P4M800-M Socket...
Fan
as fans with ball bearings in them operate, they gather dust. this dries out the lubricant in the bearings track. normally cleaning the fan would suffice to restore effectiveness just run a vacuum over the fan on a regular basis to stop the dust building up.
if you have added lubricant to the bearings you may find that more dust is now sticking to the dust that was already there reducing the fans effectiveness even more and causing more noise.
another possible reason for the increased noise is that when lubricating the fan, depending on how you did it, you may possibly have bent the fan's axle slightly again increasing vibration and noise.
personally I think it unwise to add lubricant to a ball bearing track such as that on a cpu fan as lubricants vary in viscosity and suitability for use and I wouldn't know which one to buy. If the axle has become bent, I believe it is possible to have it straightened but with the price of fans being so low I feel your best course of action would be to replace the fan and then make sure that your new fan doesn't get clogged.
Oct 08, 2008 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Fan
instead of cleaning it by taking it apart,
try to clean it without taking the cover out.{hassle free}
tools needed:
2 cottonbuds
1 powerful blower{hair blower will do}
1 alcohol/water{used if the dirt is hardly stick in the spindle}
instruction:
hold 1cottonbud and place it between the spindle{to make spindle not to spin while cleaning}
take the other cottonbud and poke the dirt out of the spindle one by one
then use blower to blow and clean the dirt out of the fan
dip cottonbud to the alcohol solution and use it to clean the hardly poke dirt
then blow dry your fan
Oct 06, 2008 | Ultra ThinkCentre M51 SFF P4 541 3.2GHz...
Fan Noise
The best solution is that you have to buy another new Fan for your pc before it move out of hand.
The fan is faulty and the little checking you have done is some how recommended for the fan to have work better but since then you have to change it for a better one before it have anything to do with your processor Malfunction.
bye.
rate this solution .
Computers & Internet Logo
165 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
