Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate FreeAgent Desk Top
Hi
I have one of these wonderful Seagate units which craps out. There is no power, so I have pulled it apart and found that component L13 is burnt out. Can you tell me what L13 is so I can replace it? It appears that it somehow links the negative terminal and the earth path on the board.
Many thanks
  • 1 more comment
  • tonywu738 Feb 12, 2009
    There is no power, so I have pulled it apart and .......
    How did you pull the power apart? I have the 1.5 TB Free Agent Desk and can't access my photos, but I can seen thumbnails and can access one photo before it crashes.
  • Anonymous Feb 22, 2009
    Not detecting drive in manager.
  • armendi_gl May 11, 2010
    aaaa
mbase213
  • 728 Answers
SOURCE: seagate freeagent drive
Hi George,
The seagate freeagent should be reconigized by windows. The question is are you adding an additional partition or do you want to create a brand new partion. I'm assuming you want to add.
You can add more space to existing primary partitions and logical drives by extending them into adjacent, contiguous unallocated space on the same disk. To extend a basic volume, it must be formatted with the NTFS ile system. You can extend a logical drive within contiguous free space in the extended partition that contains it. If you extend a logical drive beyond the free space available in the extended partition, the extended partition grows to contain the logical drive as long as the extended partition is followed by contiguous unallocated space.
  1. Open Command Prompt.
  2. Type: diskpart
  3. At the DISKPART prompt, type: list volume
    Make note of the number of the basic volume you want to extend.
  4. At the DISKPART prompt, type: select volume n
    Selects the basic volume, n, you want to extend into contiguous, empty space on the same disk.
  5. At the DISKPART prompt, type: extend [size=n] Extends the selected volume by size=n megabytes (MB).
Value Description list volume Displays a list of basic and dynamic volumes on all disks. select volume Selects the specified volume, where n is the volume number, and shifts the focus to it. If no volume is specified, the select command lists the current volume with focus. You can specify the volume by number, drive letter, or mount point path. On a basic disk, selecting a volume also gives the corresponding partition focus. extend Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus. A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command, you can extend an existing volume into newly created space. If the partition was previously formatted with the NTFS file system, the file system is automatically extended to occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format other than NTFS, the command fails with no change to the partition.
You cannot extend the current system or boot partitions.
size=n The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk is extended to take up all of the next contiguous unallocated space.
Notes
  • To open a command prompt, click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  • You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
  • To extend a basic volume, it must be formatted with the NTFS file system.
  • You can only extend a basic volume onto the same disk.
  • You can only extend a basic volume if it is followed by contiguous unallocated space.
Hope this helps!
Thanks
Mark
Posted on Jan 04, 2009
  • 85 Answers
SOURCE: Seagate Freeagent not being installed
beck up your all files, then install a New Operating system, u install and un-install it, therefore it seems that some files are missing. and the fact is not installing and showing the device again.
so install a fresh O.S, and install it again,, and Enjoy..
good luck
shafky
Posted on Jun 26, 2009
pcpal
SOURCE: Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Posted on Jul 25, 2009
KingDWS
  • 1606 Answers
SOURCE: my Seagate FreeAgent Desk 1 TB worked for several
There is about a 40% failure rate on these drives which is extremely high. The problem is a error in the onboard bios. If it is still working you can apply a update that will fix it. If it has "bricked" or locked up then you are out of luck. You can try to return it under warrenty. If you have important data on the drive then you may need the services of a data recovery company to get it off ie $$$ to do.
Posted on Dec 30, 2009
  • 218 Answers
SOURCE: my son knocked the seagate freeagent down and it
Probably bad. Is it not being recognized by your system, no matter what you do?
Posted on Jan 05, 2010
Tip
Seagate FreeAgent Desk 500GB not reconized and just beeps
Hi, anyone looking at this tip please be patient as the link that was below is changing to another site, it shows a link from You Tube on how to take the Seagate apart so anyone with the problem with the unit just making beep sounds and not being reconized by their P.C.
As all the threads i saw like my 1st thread reporting about my friends Seagate FreeAgent Desk 500GB asking about his problem and no-one was getting replies, and they where getting frustrated, I decided to find out. Someone has replied to my other thread with the same answer as taking it apart and connecting it to a P.C. So to help others who need their important files from the external HardDrive I have made a step by step guide so even novice P.C. users like myself can attempt to sort it out without being charged loads $-£ etc.. It seems unfair for all these users to buy something new and with in 1 week - 2 months it fails and they have important files etc.. stuck on the HardDrive and being charge to retrieve it. I'm not looking to cause any trouble just want to help others out. (link no longer availiable, it is being amended)
on Aug 17, 2010 | Computers & Internet
Whys is my backup plus not showing connected
HI,
Seagate Diagnostics for Mac Software:
Designed to check the overall health of your Seagate FreeAgent Go for Mac and FreeAgent Desk for Mac drive. Please Follow instruction.
http://www.seagate.com/support/downloads/item/seagate-diag-mac-master/
http://knowledge.seagate.com/articles/en_US/FAQ/207851en
Thanks,
Mac Support
May 31, 2014 | Seagate new 3tb backup plus desktop for...
I have a Seagate FreeAgent Go, 500 GB, sn2GE6NC5Z. My computer crashed and took it in for repair with the seagate. In fixing the computer, the service person erased everything on the seagate drive. Is...
FreeAgent™ Software Version 2.1.600 includes folder encryption. This download is compatible with all versions of 32- and 64-bit Windows. This software may be used in conjunction with FreeAgent DockStar™.
FreeAgent? ' Go Software Download for the FreeAgent? ' Go in case the software has been deleted from the drive
FreeAgent? ' Desk Software Download for the FreeAgent? ' Desk in case the software has been deleted from the drive.
FreeAgent? ' XTreme Software Download for the FreeAgent? ' XTreme in case the software has been deleted from the drive
hope this helps you
Jul 25, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
Seagate pn 9ZA2A4-500: I 'think' I got a successful backup to my desk top one time. Since then, many months, I have never been able to get a successful data dump. Maintanence of a good back up to my HP...
Hi ,
Here are several back up sofwares wich could help . I still think Acronis is the best .
If you are under Windows 7 , you don't need third party programs anymore . Just go to Start , type " back up entire system " and follow instructions .
Regards .
Jan 23, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Cannot power on Seagate Freeagent Desk external hard drive
Hope this has only been used for backups, and not as a primary storage. The best way to trouble shoot something like this is to purchase a USB/SATA adapter. You will need to dissemble the device and take out the hard drive. Connect it to the USB/SATA adapter to see if the drive spins up and can be seen by the PC. This will let you know if the drive is OK and whether the fault is related to the external bay electrices or the drive itself.
Good luck, you can get the USB/SATA devices quite cheap off of eBay.
Cheers,
Ripface.
Sep 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
535 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
